Do I put the shifter in d3...d2...or d1 drag racing
Old 09-23-2017, 03:14 PM
Bobby G's Avatar
Default Do I put the shifter in d3...d2...or d1 drag racing
I'm not sure what to do with my new LS3 I have the 4 L 80e. transmission at the racetrack or drag racing around the street do I start off in D1 D2 or D3 if I start a D1 do I just shift up and RPM I want any help would be appreciated thank you
Old 09-23-2017, 03:16 PM
Bobby G's Avatar
The transmission is all stock except for the 3600 stall speed converter
Old 09-23-2017, 04:01 PM
wht/73's Avatar
D3 or lower !
I think all the clutches are engaged.
Hopefully the pro's will correct me if I'm wrong.
Anytime you feel like your going to beat it up, D3 V
Old 09-24-2017, 04:15 AM
PBA
PBA's Avatar
If the computer is set at the right shift points, then leave it in drive. If you do not want to go inside the transmission right now, then adding the TransGo HD2 Shift kit will help with the 3rd gear clutch to live much longer by the Shift kit increasing the holding of 3rd gear by apx. 300%. This is the weak point in the stock 4L80E. If you are going to rebuild this unit, then there are other ways (if you do not use the TransGo HD2) to get the full apply of the 3rd gear clutch pack. What year transmission is in here?
Old 09-24-2017, 05:56 AM
wht/73's Avatar
PBA, when you say drive, you mean D3 and let the computer shift correct?
Or, if manually shifting, using D1,D2,D3
Old 09-24-2017, 08:41 AM
Bobby G's Avatar
My transmission is out of a 2007 2500 HD truck
Bobby G's Avatar
It has 53000 miles on it
Old 09-24-2017, 09:18 AM
01ssreda4's Avatar
D3, per my long time trans builder. It manually engages the low roller clutch? Either way he said do it every single time. No 4l60e failures yet!!!
Old 09-24-2017, 06:42 PM
wht/73's Avatar
So the 60E does the same thing?
Old 09-24-2017, 08:39 PM
clinebarger's Avatar
Not from the factory, 4L60E's require a modified 2-3 shift valve along with a
valve body mod.
The 4L80E does this by design.
It's the Overrun Clutch that comes on to help support the Overdrive Roller Clutch in a 4L80E in D3. Though Sonnax does have a kit to keep the Overruns on in ALL gears but 4th......http://www.sonnax.com/parts/4496-sma...utch-valve-kit
In a modified 4L60E, The Overrun Clutch also comes on.....But to support the Forward Sprag in 1st & 2nd while the shifter is in D3.
Old 09-24-2017, 09:31 PM
wht/73's Avatar
So the advantage would be you could leave it in D4 and be rough on it from 1st through 3rd without worrying about killing the OD roller clutch?
Old 09-25-2017, 12:01 PM
You got it! I haven't run one of these yet or even seen the parts in person, But I think it puts straight line pressure to the Overruns that is routed through a valve.....4th gear oil strokes the valve & exhausts Overrun Clutch.
This is probably more suited to heavy duty applications, Creates new possible leak points.
Old 09-25-2017, 12:52 PM
Restricted User
JoeNova's Avatar
The 80e in my Nova took a crap on the strip a few months ago.
I had it in Drive (D4) and launched. I spun when it shifted into 2nd. I let out and got back in it. I think that it had upshifted to 3rd or 4th when I lifted because I was doing 65 at the top of 1st, and then downshifted hard into 2nd when I got back into it. It acted like it was in neutral in 2nd. It had been acting strange on the street for a few weeks, slipping on the 3-2 shift but I assumed it was tire spin.
Now the trans will not move forward in Drive (D4). If I put it in D3, it will drive first 3 gears OK. It also doesn't have reverse.
Stock 80e with transgo HD2 at ~800whp with 150k miles and 2 years of heavy abuse. Now I'm having trouble finding someone to do a mild performance rebuild on it for a decent price.
Old 09-25-2017, 01:28 PM
PBA
PBA's Avatar
JoeNova You could rebuild it yourself. They are easier than the 4L60E to do. A lot of information out there on these.
Old 10-05-2017, 12:57 PM
Slick68's Avatar
R for Race mode!!
Quick Reply: Do I put the shifter in d3...d2...or d1 drag racing
