Need help identifying these injectors
when I bought my gto the previous owner gave me a bag of injectors, he says they’re better for my blower set up. I’m not sure what size or kind they are.
i tried uploading a pic but I’m not seeing it on my end, let me know I y’all can see it.
No pic...
It did. You're good!
No way of ID'ing an injector without numbers or anything. Just a blue injector..
yeah, I looked everywhere and there are no numbers whatsoever on them BUT.... the bag the owner gave them to me came in said:
01tk10056
r-1092
1-4
these numbers probably don’t mean anything, could’ve been a bag for something else but it’s the only numbers I could find.
I was hoping they could be identified like ford injectors, by color. If anyone can tell what they are it would be much appreciated.
The only way to know what you have is to flow test them. Then you will KNOW.
Which SENSOR?
Oh OK, injector, not sensor...
Get them flow tested. Then you WILL know what you have.
Send them to a fuel injector service place.
Will do, you think they can find out the cc’s too, sorry for the many questions I just want to be sure they’re better than what I I already have in my gto, also want to give the tuner as much info as I can so there aren’t any hiccups while tuning. Thanks
Yes when they flow test them they will do it at 10% duty cycle increments all the way to 100% which is static. The static flow is how injectors are typically rated so if they flow 750cc at 100% (static) then they are 750cc injectors. and you mine as well have them cleaned to when you send them off.
alright, sounds good! Will report back when I get them checked.
