PCM Cooling Fan Wire Hot When Off
I was attempting to install a lighted push button switch for my elec fan and I was surprised to see it light up when the ignition was turned off! Why is my pcm fan gnd putting out 12V when off? Ive attached a diagram of how I have it wired. Its working fine. I simply have the fan hi switched to gnd.
The PCM is not powering them with +12V.
This type of outputs are grounded by the PCM to activate them, when deactivated they go to a "floating state" and the voltage you see at the pins is a residual or leaked voltage that passes thru the relay coil. If you want the bulb to remain off then you should use a IGN wire to power the relay 86 terminal from your drawing instead of having it permanent from battery.
Relays are just switches, depending on how you wire them, they are a open / close circuit. Open contacts do not bleed voltage, unless their shorted (welded together) or broken. The coils need power in and a source on ground. The only way a relay can maintain power when voltage is remove, it will be known as a timer relay which has a capacitor (that hold current) in it to maintain voltage at a timed / determined period.
You can try a solid state relay, but the solution is there, use a IGN feed instead of a direct connection from battery which you should not be doing anyways.
I guess you are right, I should just switch them to IGN.
[QUOTE=JensenB;20086962]Well, as soon as I unplug the relay, with IGN OFF (with pcm) the switch light goes out. Ive tried another relay and it did the same. I will have to bench test these to confirm..
I need the make & model # of the switch. to see how it should be wired.
