Street driving difference between 3600 stall and 4000+ stall
My car right now has a 4000+ stall in it and honestly I'm getting a little tired of driving it on the street with it. Tuner has done most he can with it and it is better than it was but still rpms stay up around 3000 going through the gears, it's an 8L90 so it has a lot gears to go through.
I'm thinking of having it restalled down to around 3600, circle D said that would be ok with my decent sized cam, but would it be worth it? Would it help street driving enough to warrant doing it? How would it affect launching? I can rev to about 3500 now on the foot brake before it starts trying to push though the converter.
LS1Tech Sponsor
weight, tire size, gear ratio, cam specs, engine specs, power adder(if any), shift rpm
-Dalton
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
tire size is 305/45/17
cam is 229/239 .635/.635 111 LSA
engine is stock other than cam
no power adder
shifts around 7k
My issue is I have a 4200 stall right now for this cam and street driving sucks, rpms are always around 3500ish when pulling away from a light or driving under 60 mph. I was hoping I could restall it to around 3400 or 3600 since I am going to add a procharger soon anyway and was told I need to tighten it up for that and that it would also cause it to shift a little earlier in everyday driving.
LS1Tech Sponsor
It's a 2016 Camaro SS so 3600ish
no power adder
shifts around 7k
no power adder
shifts around 7k
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
Sounds like to me the shift rpms are too high and lockup is too high. can it short shift the 1-2 and then lock it after the 3rd shift or something like that? or will that lug it too much? I've played with timing and got alot of the lag feeling out before, if your timing isnt optimized (alot of tuners wont go through the trouble out getting the best you can out of it, not saying yours didnt...but could be a factor) then not only will it feel sluggish, it'll feel like a bigger stall than it is.
Thanks for the posts, I think I'm just going to deal with it until I go procharger and have it stalled down to around 3600.
Here is a video going through the gears driving normally. Look normal to you guys for a 4200 stall?
https://youtu.be/5c3CLh1mMTs
Here is my 4400. Different trans, rear gear and converter company but it's a loose n/a converter.
I like loose converters lots
Looks perfect to me.
https://youtu.be/EytOniqYP7M
Yeah that looks almost identical to mine. I am sure it is running the way it is supposed to I was just wondering if dropping it down to around 3600 would make it not rev as high in daily driving.
