Cobro VS Big Cube Camero
7 Second Club
This vid is a 8.0 pass with first gear traction issues (see log under vid). Prep was regular type street night at my track. DA was 3100ft with a head wind.
8.0 log
For comparison, here is the 7.8 log. No one got a vid of this pass
Notice that it's the same toon up (timing/AFR/Boost), just a much cleaner first gear RPM due to way better traction.
8.0 log
7 Second Club
Thanks Jay!
You can see in both logs where the timing was pulled in the green RPM line in first gear. 8.0 log 3 times before the 1-2 shift and once in the 7.8 pass. (note the the 8100 limiter was also touched on the 1-2 shift in the 7.8 pass)
7 Second Club
7 Second Club
7 Second Club
That NA Camaro just isn't as fast as that boosted Cobra, plain and simple. Nice run though!
Hmmmm...Curious to know what that Cobra has for a turbocharged power plant while we're at it too.
7 Second Club
7 Second Club
It's a 4.6L 4V, "drop in rods/pistons " and an 88mm Bullseye NLX.
8.0 log
8.0 log
7 Second Club
lol
Tanks!
TPS is flatlined in the logs, hard to see in the pics though. No lift there.
Which line are you looking at? I've got 6 parameters in play on the logs.
Tanks!
