LQ4 build for boost
So after much reading, lurking, and necromancy of threads ive made a desicion on how im building my newly aquired 6.0L LQ4 bare block i happend across for $150.
The engine will eventually be replacing my 98 TA's LS1 thats already running a gt4t turbod setup, thats got a built 4l65e, 3800 stall, 255 ractronic pump and hotwire, 60lbs injectors, and a full return fuel sytem with Boost referenced FPR.
i think i got my bases covered i think, but curious if ive missed anything?
It's amazing what changes in nearly 4 years...
I'm not gonna delete my original intent just to see the difference in build with what I'm actually running.
After a COVID, a deployment, and trashed LS1, finally getting around to building this thing, here's what I've gone with so far...
Stock 6.0L LQ4 with a light flexhone cyclinders
stock Ls crank
Clevit main bearings
stock gen4 rods
clevit rod bearings
stock ls2 pistons
sealed power 979K piston rings
Speedmaster Head studs
stock 241 ls1 heads
BTR Ls9 head gaskets
Pac1218 valve springs
BTR ls7 lifters
Texas speed 7.400 stems
summit pro stage 2 turbo cam 226/230
VSR 7875 GEN 2.5 billet turbo
80Lbs deka injectors
Racetronic 340 dual pump kit
LS6 intake
holly sniper 92mm TB
If you plan to tackle this simular build here's a few things you'll need or want, or both lol
Tools and garage:
Jack and jack stands, or a lift if you got the room/money
LS crank balancer removal and install tools
Big breaker bar and/or a beefy impact wrench
engine hoist and stand, even if you're dropping it
stock Ls crank
stock gen4 rods
clevit rod bearings
stock ls2 pistons
stock 241 ls1 heads
BTR ls7 lifters
LS6 intake
Tools and garage:
Last edited by JoshuaGrooms83; 01-01-2024 at 03:56 PM. Reason: Change in build direction
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20191231_155643_c58bb0e57be46476eb2a018fa3e5f1541a3e3e39.jpg)
The eventual canidate
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200707_121007_4deff50453bdfa86f04f4616530d6649e0bb0045.jpg)
![](https://cimg3.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200707_121002_a15fbeb663013a0c16918fb4d00448eafaee6e34.jpg)
mains look to be in good shape
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200707_121121_92db78045e8711f139e37a4ae58b74d858c4f645.jpg)
bores are pretty clean. need a crosshatch job, but if i wanted to do a sloppy junkyard build, i could slap in some stock lq4 rods and pistons in... which i have lol i almost did, but decided against it in favor of forged
![](https://cimg8.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200707_121036_f6fccbdded06b978aca08da4944a88f9093bbf2a.jpg)
cam bears are actually still intact
![](https://cimg0.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200707_121241_7e46925fa51fcfafcbdffe8934baa86dfd330698.jpg)
![](https://cimg0.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200707_121247_9dc93b78f366bc69311e5c646954f5a6657b76bd.jpg)
![](https://cimg3.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200520_160243_3d0e311bffe259351f4fe7e44cae40c7d2aec6e2.jpg)
pile of goodies
![](https://cimg0.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20191203_180234_bbc2c986a0cbd767ad1be5c609b697bd5b13ab8f.jpg)
317 heads
![](https://cimg3.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20191123_160442_738556aed13c9ef74277bbc9c0da1fe511b2cb70.jpg)
changing the springs over
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20191011_174424_b9a58db952c311aaa0b6e23fead10c5b33ca8f1e.jpg)
the cam that was gonna go in the ls1, but decided just to build an entire engine 😁
![](https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20191011_174344_959e1e0b58083b5f0299e7dac4637ef4ff225810.jpg)
ls9 gaskets
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20191011_174355_2dd55ff483742cff85b04e3fe3be2fbc3e5a1f35.jpg)
got myself a balancer puller and installer
![](https://cimg3.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20191011_174357_0751b25b230e79d5416a526b811a3ecead23abf2.jpg)
still got more gaskets coming
JoshuaGrooms83 (07-24-2020)
this is a trial in patience and discipline right now lol I had gotten a set of LQ4 pistons initially, and they keep staring me in the face everytime I open my garage lol only thing keeping me from ring gapping and stuffing them into the block currently is I really want to send the engine out to get checked, cleaned, and 4.005 bored, and I really want to put new clean bearings on new clean forged internals on the stock crank. plus i still gotta get a dampener for when they balance it as well lol
getting the little stuff for now. love the delivery guy right now becuase almost everyday is a new car part 😁
Basic SBE LQ4
JoshuaGrooms83 (07-26-2020)
![](https://cimg0.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200809_172417_8663d53242571f508b54012d120aa9294b423271.jpg)
Finally got it on the engine stand
![](https://cimg1.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200809_172429_611de8c82cccca915b96e1d82bbcc760c050b864.jpg)
better view of the 6.0L
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200809_172405_73650345d5d6bd08850dbf483d70985b2d7de2ac.jpg)
some gen 3 pistons i picked up. wondering what to do with em
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200809_181809_2f3c10dfbec5bd6ab2260e25e8a6400b184686db.jpg)
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200809_181805_02e134f11c979f72c0dc25f7d89ac45a25b6dd64.jpg)
decided to clean them up and see if maybe...
![](https://cimg0.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200809_181953_7776897fad3a6171fd5e646a9e9d7f920477cdee.jpg)
the bores dont look bad. could use a hone.
![](https://cimg1.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200809_181958_6b75fd4d9ad6158dbb4a9ec217e5088f95879245.jpg)
just checking stuff out. pullong the old sensors out. who ever pulled the engine sheared off the oil sensor lol
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200809_182005_b3d43273353b3071b751a62df57a202c4e33d101.jpg)
slowly cleaning her up
![](https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200809_182028_aa0270e19ceced58f40397fa685962b0b655fefb.jpg)
man the oil rings were dirty!
Decided to test out the rings and see what they were in the bore. Looks like they are right in the turbo range... all of them. .027ish for all the rings, top and bottom.Starting to think i might start with either these pistons or see if i can snag gen 4 pistons. Waiting to see if an offer goes through.
i think for now, im gonna get it hot tank cleaned, checked, and honed, and then sloppy mechanic style, slap gen 4 rods/pistons, and stock crank back in it, and stick the turbo cam in it with 317 heads. Gonna shoot for 800rwhp range, so gonna need more fuel but i think i have everything i need currently to put this thing together.
with 317 71cc heads, lq4 6.7cc dished pistons and stock rods, ls9 .054 gaskets, and the 364 block, the compression ratio is 9.4:1cr, and add in a mild 226/230 cam, and 15psi of boost with 80lb injectors, a walbro 450 pump, methanol injection, .... i think i have decent start
JoshuaGrooms83 (08-22-2020)
Nice! i look forward to trying out this summit cam. I have new cam and main bearings on standby and I'm gonna get new rings too since they are cheap enough anyway.
I decided on a more stock bottom end with gen 4 rods and pistons as im keeping the power a tad more modest around 800hp. it will also allow me to better afford a slight larger but not nearly as big turbo for a 1000hp build. my gt45 is huffing pretty damn good with the ls1, and its good for about 700. I'm thinking a s475 or s480 will be the next step for the 6.0L and keeping the rpms to about 6500ish.
![](https://cimg1.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200904_122812_bd7dcd50ad4446b1733de8f1316f346c63165846.jpg)
got a set of 4th gen LQ4 pistons and rods today for pretty cheap. gonna hold the gen 3 lq4 piston and rods for backups or if something else comes up.
![](https://cimg8.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200904_122806_ea1e05b2f9a61a78a5944af57ddde8dabd1584c0.jpg)
set of 4th gen lq4
![](https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200904_122846_fdf66f292ee245065316df99e4a1ab313ab0c6e1.jpg)
lq4 with valve relief on the left (im assuming DOD) and a LQ9 flattop with gen 4 rod on the right. Im actualy gonna replace the dished pistons for flat ls2/lq9 pistons. this will keep my compression at 10.1 w9th 317heads and keep low rpm/no boost tq up while also utilizing the better flow of 317 heads. the floating pins make swapping a lot easier
![](https://cimg0.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/20200904_122853_f0262110bc4ab157b2dbd807ecb75a26640b83e8.jpg)
got 9 in the box lol and i bougt the flat top one by accident on ebay. so if i was trying to build a v10 i'd be close to something lol at least i have a spare set of rods just in case.
JoshuaGrooms83 (09-07-2020)
The following 2 users liked this post by 68roadrunner:
Jimbo1367 (10-02-2023), JoshuaGrooms83 (09-21-2020)
I'm curious what people recommend on these rings? I've come across hastings rings for like $84 which isn't bad. I keep coming across that Moly rings might not be the best option though for boosted engines due to flaking if they get too hot. this is one of those pandoras box topic I'm sure but lol , any recommendations?
Is that an optical thing or is the coolant passage blocked?
Jimbo1367 (07-12-2024)
Oh for sure, I'm holding off on anything else until I get the block cleanup and at the least honed, but if i have to get bored this will change a lot of what i will do then. The picture is just over exposure, might have had the flash on. The coolant passages could use a serious descaling/hot tank, but you can see through them. that top section is just me too close with a cell phone camera lol but its still pretty grimy in there.
Like I said, gotta get it to the machine shop to have them check it out.
![](https://cimg3.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_164019_3fbe2bb9c5961654009930c815f22d8ea8cd4be8.jpg)
ls2 piston waiting to go. swapping ls2 pistons over onto gen 4 rods. swapping piston rings is sooooo tedious lol but allows me to check and gap rings so its necessary.
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_164023_0bc155fb15653287b7e37ef9e1fe10aa11b22e8a.jpg)
4 stuff into one bank. (the new rings were .030 and .026 so I left them alone)
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_164026_bd37ba18c531e196f6b57b9a05344960ebd1e55e.jpg)
last couple to go into the engine. the BTR 4.0" piston guide was a huge help!!! piston slide in almost too easy lol had to reseat a few rod cap bearings from moving too fast lol (rods take 15ftlbs first pass and then 83degrees second pass, but 90 degrees or 51-55ftlbs according to Matt from Sloppy works)
![](https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_172114_d94b21bf9cf409b11bd54c146e1df85a7ce210e3.jpg)
summit stage 2 turbo cam about to find its new home
![](https://cimg7.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_172121_4e69a3126c29f1102d214d891db116209186de2c.jpg)
some covers and stuff lol seals actually went on alot easier than i thought they would on the front and rear covers.
![](https://cimg8.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_172517_93d32c49b767b5407a40b86681ef6cf021788691.jpg)
had to get a bunch of ict bolts since the block was bare. so it looks pretty fancy lol
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_174001_e59da232a1b558c09e0602966e7cf5f6ad754931.jpg)
cam in. lubed with assembly lube, cloyes timing set with ls2 chain. #1 top dead center and dot to dot on gears.
![](https://cimg0.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_174914_a3b3791c8bcbb3ec9777ac96f5bb10c60649f5b8.jpg)
ls7 lifter.... probably china lol
![](https://cimg1.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_174922_a7466f89f0540e6a9fc65c977fd8213132afa81f.jpg)
ls2 oil pump and put some assembly lube inside it.
![](https://cimg3.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_175443_8f194f92c1f77e9ac2ec956cc0e5133041c0c264.jpg)
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_175450_25b5604881b8df81c88dd6514ba78a8f31be56cf.jpg)
guides and lifters ready to go with some lube
![](https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_180557_eedf0d1cd8fb20041408098ed2c628b3f5e24873.jpg)
buttoned up top to keep stuff out. stock valley cover
![](https://cimg7.ibsrv.net/gimg/ls1tech.com-vbulletin/940x2000/screenshot_20210501_181827_google_5f391b9822aabbe0dcd3a1dbcc6ce55ba4a72f78.jpg)
stud guide i used for the different lengths.
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_181832_93f46ec552c1767fe67c48aad1f57b14b8f04934.jpg)
studs all pre staged
![](https://cimg1.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_181839_508a0c8fddab4ece828b0f6a618d1151045f510f.jpg)
studs all set
![](https://cimg2.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_183218_689b5aa8c0bff498f999f3124a0205b76510b1df.jpg)
rear cover set
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_185658_da976c35a3bbff117c294c062611666796c63660.jpg)
Main caps 15ftlbs 1st pass, and then 45degrees second pass (it's actually 53) and then 18ftlbs on the side cap bolts.
![](https://cimg7.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_190221_87a352d48dad4a8aca1ada1ae97ff3601c225e29.jpg)
tube brace. blue gasket ring is on the tube.
![](https://cimg2.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_190725_ebee3a5c36961c2849e89f7c0f6ac7fdc8681c36.jpg)
oil pan... did you know there were long ones in the back lol
![](https://cimg3.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_190736_6df4a9f7d86edd4330c98e4ddc53632ca68218ea.jpg)
all buttoned up
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_190959_c8fd2257978dbbaac4ad6740a383d20c685238b5.jpg)
filled with fogging oil and used to keep out moisture and dust.
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_191939_daf39ec18b8f55190d8aa1cdd7c19054b05259ae.jpg)
sooooooooo dumbass moment. make sure to put the barbell in BEFORE you put the rear cover on thats on an engine stand 🙄
![](https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/20210501_192707_01a5f98d92ee8d4550c913c0f3bf082074410a77.jpg)
called it a day but other than the oil barbell not a bad start for my first ls/lq engine build, casualy in my garage on a nice may afternoon. was also nice to clean out the garage from random parts laying around everywhere lol be nice to have all the engine parts ON the engine and on the engine stand lol
