Used LS7 head value.....
Untouched assembled they range from $900-$1200 for a set. $500 to $600 bare is what I'm buying them for at the moment.
Bob570 (06-13-2024)
They aren’t a hot commodity. Too many issues
Are you looking to sell your Veronica Daniels heads or just purchase a new set?
01CamaroSSTx (06-14-2024)
Seen where you compared LS7 cylinder heads to VD in post 9 of the linked thread below and I thought it was funny..![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
https://ls1tech.com/forums/generatio...rs-please.html
I can’t comment as to why your one exhaust guide was out of spec about an inch…lol…but I will say that I’ve seen a lot of guys post their guide wear results, and they are always very random with one or two in different spots being out waaaay more than the other guides around it. No rhyme or reason other than it’s a GM LS7 casting so expect weird results.
The coating on the exhaust valves being rough to the touch…now that seems to me like it’s almost an incompatibility between whatever guide material was used, and the valve itself. I’m straight-up speculating here without actually seeing the valves myself under magnification and miccing the valve guides for clearance numbers. There’s a couple of variables at play, such as guide to stem clearance on the exhaust side needs a scoche more than the intake side…the actual coating on the exhaust valve and exactly what is it or is it just a marred uncoated valve?…Was the guide concentric initially and was it confirmed? Was the valve stem concentric and was it confirmed? Guides get hammered in and valvejobs are done with the new guide in place, and off of the new guides location, so guide installation is critical always.
Does any of this really matter at this point, as the damage is done. I’m impressed the valve head didn’t remove itself and leave you without an engine, so there’s that.
AFAIK, the valves are uncoated. They are all hardened stainless. Intakes are Ferrea hollow stems, exhaust are unknown brand solid stem, and weigh 98g. Thank you all for responding..
Che70velle (06-16-2024)
What does AFAIK mean?
thanks
thanks
As far as I know
The following 2 users liked this post by grinder11:
Che70velle (06-16-2024), MySons68C20 (06-19-2024)
