Is this Amsoil like Techron?? Worse or Better?
Old 06-21-2024, 02:33 PM
NC01TA's Avatar
Default Is this Amsoil like Techron?? Worse or Better?
I was at a show today and stopped by the Amsoil vendor tent to see what kind of products they carry these days. This gas additive caught my eye for $10 and I put it in the Trans Am tank for the ride home. Of course the sales guy said it was a wonderful product but I don't have a clue if it's similar to Techron or more like a Lucas Oil gas additive that is less effective. On the other hand, is it perhaps better? Anyone have knowledge of this product? The bottle says use every 4,000 miles. One bottle treats up to 30 gallons. The typical cleans injectors, chambers, etc....
Old 06-21-2024, 03:58 PM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,695 Likes on 1,214 Posts
I've never used it but, if you're looking to try something other than Techron, I would recommend Red Line SI-1.
NC01TA (06-22-2024)
Old 06-21-2024, 05:00 PM
sjsingle1's Avatar
i use redline exclusively.....when i pulled my manifold off i could tell where the fuel spray was due to the spotless intake tract in the head
NC01TA (06-22-2024)
Old 06-21-2024, 07:14 PM
MASS seller approved
low2001gmc's Avatar
Amsoil makes good products. Good to know about Redline Additive. I've used the Techron since a good friend said it was what they used at the Dodge Dealership he worked at the time. He said that is what they poured in vehicles, shook vehicle for better mixture, drove several blocks, returned, made customer wait hour to charge them hourly rate. I tried it on a vehicle that needed a tune up before trading and it ran like a charm afterwards. Haven't tried anything else but may be inclined to try Redline.
NC01TA (06-22-2024)
Old 06-22-2024, 09:32 AM
NC01TA's Avatar
Red Line sounds like a good product but I'll probably just stick with the Techron. I was just curious and tried the Amsoil.
When I owned my C4 I remember other owners swearing by the Techron as it kept the gas gauges working. Techron in the tank really freed it all up.
Old 06-22-2024, 12:30 PM
wannafbody's Avatar
Amsoil makes good products, just a bit pricey.
NC01TA (06-22-2024)
Old 06-22-2024, 06:58 PM
NC01TA's Avatar
Thanks. That's what I thought as well but for $10 and no tax, it was worth a try. I usually get Techron on sale for $6 or $7. Pretty close.
Old 06-23-2024, 07:56 AM
SteveC's Avatar
Location: Poway, Ca. where GOD and the sun always shines
I have been using "Gumout" fuel system cleaner in Sara (2001 Z28) for over 22 years with no problems or issues, it is also reasonably priced @ $7.87 @ Wallyworld.
NC01TA (06-23-2024)
Old 06-23-2024, 12:17 PM
SAPPER's Avatar
The P.I. is used as a additive for every few months. What you'll want to do is use the P.I. first, then use the Amsoil Upper cylinder lubricant once a month.
If you get a PC acct it'll be a lot cheaper.
Many of my small engine accounts will include a bottle of PI after rebuilding their engines.
I am an Amsoil dealer, but when it comes to fuel additives, I will recommend Amsoil, of course, But Lucas of Seafoam are great as well. IMHO, Redline is like Royal Purple. Its a marketing thing with zero proven test results.
No other lubricant company in the world tests their products to the extent of Amsoil. Just ask Gale Banks. If a product is garbage, Gale has no problem calling them out...by name.
NC01TA (06-23-2024)
Old 06-23-2024, 02:41 PM
Treburkulosis's Avatar
Redline is what I normally use. I am going to give lubegard fuel a try. I have had excellent luck with their kool it and biotech.
NC01TA (06-23-2024)
Old 06-23-2024, 04:58 PM
RPM WS6's Avatar
Red Line does publish test results. It can be found on their website under "White Papers" for a given product (including SI-1). Not sure what you consider to be "proven" in terms of these results, but I have personally used the product to successfully clean up more than one fuel system over the years.
The following 2 users liked this post by RPM WS6:
NC01TA (06-24-2024), Treburkulosis (06-24-2024)
Old 06-23-2024, 08:55 PM
sjsingle1's Avatar
i am sure the amsoil is a great product.....redline has proven it works to me....and i can get it anywhere instead of just a redline dealer....a plus in my book
The following 2 users liked this post by sjsingle1:
Old 06-24-2024, 06:05 AM
I haven't seen amsoil let us know how it does. I would like to try it in my wifes Jeep if it works well.
NC01TA (06-25-2024)
Old 06-24-2024, 06:53 AM
Y2K_Frenzy's Avatar
Default Check out the SDS
It appears that Amosil is similar to Seafoam and that naphtha is a main ingredient (paint thinner). It’s a little bit weak sauce. When you’re looking for fuel system cleaners look at the SDS for something that contains polyetheramine or PEA.
https://www.worldsbestoil.ca/amsoil-msds/api.pdf
Old 06-24-2024, 06:57 AM
Interesting find. Anything on Lubegard?
Old 06-24-2024, 12:38 PM
RPM WS6's Avatar
So I just looked up the SDS for Red Line SI-1...main ingredient is very similar to Amsoil, and Red Line does include PEA. So if Red Line is nothing more than a marketing thing, then Amsoil isn't any better.
https://netmsds.phillips66.com/ViewP...SubFormat=USDS
Substance .................................................. ................CASRN............................. ........Concentration
Distillates, petroleum, hydrotreated light.......................64742-53-6.........................................<70
naphthenic
Alkoxylate of an organic alcohol (PEA)...........................ACCN 102728................................. 30-40
1-Propene, 2-methyl-, homopolymer,
hydroformylation products, reaction products with............337367-30-3....................................<2.49
ammonia
NC01TA (06-25-2024), Treburkulosis (06-24-2024)
Old 06-25-2024, 09:31 AM
NC01TA's Avatar
OK, I will. Probably won't notice a thing to be honest with you. I just do it for annual maintenance. I never noticed anything with the Techron either. My cars all run very well.
Treburkulosis (06-25-2024)
Old 06-25-2024, 09:58 AM
MuhThugga's Avatar
I used to be on the Amsoil bandwagon, but have since gotten off and not looked back. The products are good, but they are overpriced and comparable products can be purchased at your normal retail stores for cheaper. Plus, the fanbois constantly propping Amsoil up as God's gift to the automotive world is exhausting.
As for their fuel cleaner, it works, but I just get Techron every so often when it is on sale. And by that, I mean I use it once every 5 years or so.
NC01TA (06-26-2024)
Old 06-25-2024, 10:07 AM
If you are putting good gas in them you probably wont. I run 93 in my Ecoboost Flex its got 21k on it and you would never know its not brand new. The Z needs a fuel system clean up. I run 93 in it. The wifes jeep I just put 87 in it and you can feel it. Its got 29k on it now. It needs a clean out and I need to just start running 93 in it as well.
NC01TA (06-26-2024)
Old 06-25-2024, 10:17 AM
Y2K_Frenzy's Avatar
naphthenic
ammonia
They say the PEA is where the magic happens. It can withstand higher temps than the other chemicals so it doesn’t get burned up before it has a chance to clean.
Quick Reply: Is this Amsoil like Techron?? Worse or Better?
