How much water can you inject?
Have a higher compression ls1 that appears to just not want to let go so im going to drop a few pulley sizes. procharged, heads cam car. makes 10psi at 6k and close to 11 at 6500. Running 15 degrees of advance. I will be dropping from a 4.38 to a 4.13 so hoping to see eh 12 or so..
Been just piddling around with the car waiting on stuff to come in and decided to maybe revisit my meth setup and possibly go to a dual setup. Snow kit, right now im running a 12gph or 757ml/min nozzle spraying 50/50. I found an old post by I think aquamist saying to multiply total CC of injectors by 15-20% for a 50/50 mix. That seems like a LOT of nozzle compared to other peoples setups. I did find this nice little calculator but it too suggests a very large amount of nozzle. https://www.customperformancesolutio...injectioncalc/
Ive searched a bit on this and most people here are ***** to the wall running massive nozzles on 100% so info is few and far between but this 1100ml/min according to aquamist math comes out to an 18GPH nozzle. This is a lot more nozzle than I've seen the few people running water mix suggest in the past.
Thoughts on this?
Thoughts on this?
My limited experience, plus a lot of 'reading' suggests that there is a world of difference between straight Methanol and 50/50 Windshield washer fluid.
50/50 Washer fluid will bring down IAT, and allow greater manifold pressure about the same degree as a cold winter drive versus a hot day in dense traffic (heat soaked air intake).
Straight Methanol is FUEL, with about 130 Octane. Methanol stoich is somewhere close to 6 to 0ne AFR, and will make power down to 5.8 to one. Methanol is half oxygen by molecular weight, so you can push a LOT of it into a cylinder.
My point is that you need to decide if you are JUST providing a cooling MIST, or if you are essentially going to run a DUAL fuel engine, if you dump a serious (stoich) quantity of Methanol you'll both have to accomodate that into your fueling tables IN the boost region, ie LESS gasoline AND your tune will be 100% dependent on the METHANOL tank being full, and the pump working, or you'll melt pistons.
Let me state that another way:
IF you run straight Methanol , and TUNE for it... You're HOOKED on it.
LilJayV10 (07-09-2024)
I tune myself. My VE table looks like a bowl up top because of the methanol. Without the water in it this car would probably not have cyl 7.. If E was closer and more available I’d consider that. I have the fuel system for it and would just need an injector swap.
Back to the topic, it’s odd if you go by snow’s chart it suggest a super small nozzle compared to what I see recommended and used by some here. And then calculators are on the other end of spectrum and recommend way more nozzle even for 50/50 along with aquamist. What gives? I thought I was running a decent sized nozzle already for my setup but am now finding conflicting info on it. Should I really be running 18gph of 50/50 for 11-12 PSI on a centri?
Right now on the meth im around 70-80% IDC on boost ref’d at 4 bar base.. I don’t feel any bog but I have the ramp in setup early and it’s on full duty before peak torque. I have 4.11s so you wouldn’t feel much of a bog anyway lol. Hopefullly will be sending my rear to MWC to get some 3.70s and a refresh this year. 4.11s were nice when NA but constantly blowing drag radials at 60mph and having to shift like mad isn’t exactly optimal. I just find it odd that the proper meth nozzle sizing is all over the place depending on who you ask. I’ve got a message into nitrous express asking them the same question as well
Can only say this , I run 1000cc/min of home made 50/50 all in at around 4-5 psi on my turbo 6L , no bog and haven't blown up the SBE in 31,000 miles ( only added the the extra 375cc/min maybe 2000 miles ago in preparation for more boost ) 15.5 currently on 91 octane. Hope this helps
I'm running an AEM setup with dual nozzles spraying 1500cc with boost juice on my 9.3:1 forged 370 pushing about 17 psi right now. It's a progressive controller and I start at around 6psi and all in by 15psi. I'm also running 91 pump gas. Gonna start creeping up to 20+ right away. My nozzles are about 18 inches from the TB and before the IAT sensor. I run a Holley Dominator ECU and have just been letting the ECU take care of the fueling. No bogging out and plugs look good
Damn this making me think I’ve been under spraying a little vs what I could get away with compared to what you guys are doing. I ordered two 8gph nozzles so I think will be around 1000cc
it would be nice. Like I said I tried to search and damn I feel like a tadpole in a big pond around here lol. I don’t make 4 digit hp numbers like these fellows on here do. Maybe someday when this motor lets go I’ll get closer
yea I kind of just got trickle down info on it and went with something I saw on here. It’s definitely not a real adamant answer on here with everyone’s setups all over the place! But either way, more meth nozzles in my garage the better I guess for the future plans.. Next course is deciding on what rear gear I want to swap too. That is a toss up as well between 3.70s or 3.5 when on a stock 26” tire.. I still have 4.11s and they are pretty horrible with the FI setup. Might as well forget you have 1st and 2nd cause all they do is make a bunch of noise.
I've got a 4l80e with a 3.25 rear gear in my car with a 26" MT drag radial. It's got a Circle D converter in there but it kinda makes it a bit of a dog off the line. I either need to work on the tune more or just get rid of it cause it's not doing it for me and get an FTI converter
FWIW, 4.10s to 3.70s is very close to a 10% change in rpm and torque multiplication, I think of it as 10% less torque at the wheels, about 17% for 3.50s . Don't have a centi but this is a good reason for boost control on a turbo . I run 3.73s with a 29.6"tires in my 4400 lb + truck and without lower boost for street driving would be impossible to hook up , mathematically that's the same as 3.25s and 26 inch tires
