Tfs 235 vs 821 rec ports 416ci
I know this is going to spark some back and forth but let's see how it's goes.
I'm considering selling my tfs 235 in favor of some ported 821 rec ports. Since I'm running a 416, is there anything to gain power wise?
I'd like to see proof either way.
I'm just wondering if anyone has tested using a good cathedral port head and swapping it to a rec port either oem or aftermarket and seen huge gain on a 400+ cube motor
SlowTBSS (Yesterday)
What do you make for power now? I personally would see about having the 235's ported like Dave said. can make great power with the cathedral port heads and keeping the port volume smaller will be much more enjoyable, for me anyways. I have a 235 head on a 402 right now.
To switch from a TFS to a ported stock LS3 head is backwards. If you want to go faster, either port/big valve the TFS heads or go LS7 architecture and pic a head. The only reason to run LS3 port is if you are already invested in it and don't want to change other things.
I think it would be a mistake and going backwards as already said.
A 2.08 valve isn’t limiting that head. Tooley himself said they experimented with valve sizes when developing the tfs stuff and bigger didn’t gain.
having said that, I’m assuming that was a bigger valve on same csa port. Port the head some, then it’ll like a bigger valve. Not an ls3 valve, but likely a 2.10.
