Blown 427 dyno Results...
Built and Tuned by one of our customers, Adam Bird Performance, 427CID LS with Whipple charger. Custom Hyd roller under .650 lift and in the 240's for duration, Morel 5206 Lifters with .750" wheel. Dyno'd with 11#/s of boost on 91 Octane. Dyno fuel flow meters were unplugged, monitored with lap top.
The following 2 users liked this post by Cstraub:
01CamaroSSTx (08-07-2024), LaBLKv6Z (08-07-2024)
Jimbo1367 (08-09-2024)
MySons68C20 (08-07-2024)
Ls1Rx-7 (08-07-2024)
Look for an old Motor Trend article on "Thomson Automotive exceeds 1,000hp with blown LS7." He stopped just shy of your HP totals in favor of long term reliability. If you're bumping the rev limiter up hoping to see 1,100hp, IDK.....Youre pushing/exceeding the blocks strength limits, for sure. I hope your results dont match your forum name!!!!
A switch to e85 and more timing would yield 100+ horsepower. More boost and rpm and the sky is the limit.
The following 3 users liked this post by spanks13:
You quoted me on the Thomson engine. The Thomson engine does NOT use 6 bolts heads OR an aftermarket block. It uses OEM LS9 heads on an OEM LS7 block. Unless you were talking about the OPs motor.......
