ProCharger cam recommendations...
Old 07-06-2006, 04:04 PM
11 Second Truck Club
Superado's Avatar
Default ProCharger cam recommendations...
Hey guys, I have had this thread going for a couple of weeks on pt.net...
its getting so many different views, however I think the last few posts have been on the money and it was suggested that due to the fact that there are so many more Procharger guys here, to post it here as well for your qualified opinions. Here's a link to the thread, please post your replies here on this ls1tech.com thread if you don't mind...
http://www.performancetrucks.net/for...d.php?t=366243
Thank you,
Al
Old 07-06-2006, 06:10 PM
Tirefire's Avatar
I have the Lingenfilter Gt2-3 which made 526hp/510tq. Talk to Bob, at Exotic Performance Plus he'll hook you up.
Old 07-06-2006, 07:29 PM
STALL UP's Avatar
I have a 220/224-569-569/114 and love it.
Old 07-06-2006, 08:10 PM
Got Me SOM's Avatar
I run a 224/230 .581/.588 on a 115 and its a nice came and it pulls hard on top.
I would have rather run a 220/224 since my car is a street car and spends most of its time on the lower rpms but I''m not complaining, this cam has just enough "chop" to it to let ya know what's going on.
Old 07-06-2006, 09:00 PM
kp
kp's Avatar
I ran a 01 Z06 cam for nearly 2 years with great results with a D1SC. I just swapped to a 222/228 115 .566/.577 cam. Hitting the track tomorrow to see what happens..
Old 07-07-2006, 05:35 AM
EPP
EPP's Avatar
The Lingenfelter GT2-3 camshaft would be a very good choice for your truck. Bob
Old 07-07-2006, 06:02 AM
Blownramair's Avatar
KP let us [especially me] know how that cam works. I am interested.
Jay
Old 07-07-2006, 06:29 AM
BudH's Avatar
Jay
Me too! That LS6 cam has worked so well for you, I am very interested in thi difference with this new cam.
Old 07-07-2006, 08:03 AM
Superado's Avatar
Thanks for chiming in Bob...I had e-mailed you via your website, but info here is great, and I'm sure your e-mail gets swamped...
I thought the GT2-3 would be more for a Radix type SC set-up though, one that has low-end power, unlike the ProCharger. However, after looking at the specs again...207/220 571/.578 w 1.7 rocker 118.5 CL...it is similar to the ATI's suggested splits in duration and lift. The LSA is significantly higher though.
Everyone, I am somewhat cam illiterate, so thank you for your patience and explanations...the real world experience that you share is much better than theories, for sure.
Also, do you guys feel the same about LS6 springs and hardened 7.4 pushrods being the only required upgrades...re-using the stock rockers?
Any info is greatly appreciated.
Thanks again guys for all of your replies.
Old 07-07-2006, 08:12 AM
Superado's Avatar
Definitely want feedback...thanks...
Old 07-07-2006, 08:41 AM
LS1Tech Sponsor
Slowhawk's Avatar
For a 5.3l truck you really need the Cam small.If you have longtube headers you don't want much split.Also the boost level will dictate the Cam used.I'd figure 8lbs is good.
My rec.- 210/216 .550/.550 on 114 duration +2
Old 07-07-2006, 09:18 AM
stevieturbo's Avatar
Sounds just like my camshaft, and I'm pretty pleased with it.
Although for a smaller cc like the 5.3, a milder cam would probabky be the better choice.
Old 07-07-2006, 10:15 AM
LS1 Tech Administrator
Patrick G's Avatar
With a blower on a small motor, you won't need a lot of intake duration, but you'll want the exhaust lobe to be appropriate to handle the amount of power made. That means a fairly large split. Also, with a blower, you'll want to limit your overlap to around 0 degrees at .050", but you don't want to go with too wide of LSA...the resulting early exhaust valve opening will bleed off too much cylinder pressure.
212/230 .580/.592 112LSA +2 (ground with Comp XFI/XE-R lobes)
Don't let the 112LSA fool you. This cam has only -3 degrees of overlap at .050" which will limit the bleed off of boost and the narrower LSA will also keep the large exhaust duration from opening too early.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old 07-07-2006, 12:24 PM
Ed Blown Vert's Avatar
Thats very close to mine.
222/226 .585 115
Old 07-07-2006, 12:41 PM
Superado's Avatar
BTW, I do have headers, didn't realize that I didn't have it listed in sig...
Not longtubes though...
Old 07-07-2006, 01:16 PM
eb02z06's Avatar
How about Thunder Racing's new blower cam-looks similar to the CheatR cam?
Old 07-07-2006, 02:38 PM
Superado's Avatar
I don't think that the lift split being the reverse of the duration split is desirable in my application...correct?
Thunder Racing Custom "Blower" Camshaft - 214/230 .601/.575 117 LSA
Old 07-07-2006, 03:18 PM
Got Me SOM's Avatar
that's what you want, but that is a big split duration'd cam. Got a lot of lift. You traditionally want a 4 or 6 degree with split with emphasis on the exhaust cause the blower makes up for intake portion.
Old 07-07-2006, 03:25 PM
Patrick G's Avatar
Incorrect. With a blower, you want as much valve curtain area as possible during the time of duration. Lift is beneficial here. The exhaust on the other hand, is less sensitive to lift, but very sensitive to exhaust.
If you were pushing 500+rwhp NA, you wouldn't consider a 220 duration exhaust lobe would you? Then why wouldn't you run a 230 duration exhaust with a 500+rwhp blower? Big duration on the intake is not necessary when running a blower. Shorter intake duration helps keep overlap low. The large exhaust duration flows to the 500+rwhp potential.
__________________
Old 07-07-2006, 03:47 PM
kp
kp's Avatar
heh, I made 678rwhp with 211 degrees of exh duration @ .050 and .525 lift.
Quick Reply: ProCharger cam recommendations...
