do you really need the EVAP system?
Old 01-05-2007 | 02:39 PM
erikthegoalie's Avatar
Question do you really need the EVAP system?
just what it says above...I know you can relocate it, but how bout ditching it..it ruins that beautiful fast and rails I have...
thanks
erik
Old 01-06-2007 | 11:24 AM
any ideas anyone??
Old 01-06-2007 | 01:15 PM
BADFNZ's Avatar
No but I'd like to know too. I did a search and didn't find much.
Old 01-06-2007 | 02:48 PM
03 BUSA's Avatar
You can eliminate it if you are getting a tune, they can remove the codes for it. It is an emissions device that allows the fuel tank pressure to escape back into the intake and reburn instead of escaping into the atmosphere. If you are running no cats and open exhaust what is the point of trapping the fuel tank gasses?? Global warming is already here anyway we might as well just finish the job.
Old 01-06-2007 | 06:51 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I deleted all of the codes, and took off the solenoid and plugged the hole in the manifold. I just run a piece of rubber hose off of the hard line under my fuse boxes and right around to where my fog light is on the driver's side. I put a small filter on the end of the line, and was done with it.
Old 01-06-2007 | 11:03 PM
i think that is what I will do as well..
thanks
Old 01-07-2007 | 11:32 PM
code4's Avatar
I disconnected the line near the rear diff where the plastic line connected to the hard line. Then I removed the hard line, purge valve etc.
BTW could you send some of that global warming our way here in montana.
Old 01-08-2007 | 08:54 AM
ghettocruiser's Avatar
Hey guys. Couple questions... Did you leave the evap solenoid attached and just run a filter after that? Or did you go from the hardline right to a filter? Do you get really bad gas odors like that? Does your evap system do anything at this point?
Is that method basically the same as removing all the lines back to the tank, capping things off, and running a vented cap??
Of course the codes will need to be tuned out... But Im just worried about extra fuel smell, or any chance of gas coming out of that line due to the evap system being inoperative.
Thanks for any info!
Justin
Old 01-08-2007 | 10:48 AM
koolrayz's Avatar
I just removed the solenoid and plugged the line off two years ago
Old 01-08-2007 | 10:52 AM
Cobra4B's Avatar
FWIW corvetteforum member EnglandGreen yanked his on his current buildup of GROND.
Old 01-08-2007 | 11:55 AM
that sounds like a dam plan....but what about venting?
Old 01-08-2007 | 01:25 PM
ls1mongrel's Avatar
Im curous about the venting also !
Old 01-08-2007 | 10:15 PM
code4's Avatar
The evap is just a line to vent the tank. You can leave it hang where ever you decide, I chose under the car near the rear. Another option is to plug it completely and find a vented gas cap. You must plug the whole in the throttle body for obvious reasons. You will get a ses until you delete the codes.
Old 01-08-2007 | 10:37 PM
MeentSS02's Avatar
No solenoid for me, but it vents as I described. It has to vent somehow...you can't just plug it off. As for extra fuel smell venting it to the front, I've never noticed any. I don't think I would anyways though...I don't run cats.
Old 01-08-2007 | 10:45 PM
anarchy99's Avatar
Isn't there a line right on top of the gas tank that vents it? When ever I climb underneath my car and look up at the rear axle I see a vaccum looking line that isn't connected and I just assumed that's what it was. Is this correct?
Old 01-09-2007 | 10:57 AM
BADFNZ's Avatar
I'm at work so I can't look at my car, but to remove the solenoid and hose, is there any cutting at all or is it all disconnects/clamps?
Old 01-09-2007 | 11:22 AM
MeentSS02's Avatar
Just disconnecting and clamps...
Old 01-10-2007 | 05:51 AM
i see i see...thanks a lot Meent
Old 01-10-2007 | 11:43 AM
fitz98ta's Avatar
i pulled EVERYTHING on the evap system. including the charcoal cannister, line, and the rest
Old 01-10-2007 | 02:03 PM
LostCauseZ06's Avatar
good to know!!! i broke the little accordian lookin pipe and was freaking out about driving without it. now i know i dont need to worry time to get rid of the system entirely. i think ill do the PCV delete while im at it too and just run breathers.
Quick Reply: do you really need the EVAP system?
