Single Digit Club Running 9s or quicker? Damn!
will it do 9s?
Old Mar 8, 2007 | 11:51 AM
capn smokey's Avatar
Default will it do 9s?
1984 camaro
race weight-2750lbs with me in it
6.0l iron block
234/240@.50 600/612 112lsa
hooker lts
t-56 LS7 clutch/flywheel
3.73 w/275/60/15 bfg drag radials
2' drop spring 80/20 shocks in front 50/50 out back
and possibly a 125 spray
just curious thats all, it will be ready in about a week. thanks
Old Mar 8, 2007 | 12:49 PM
SSTROKED 382's Avatar
From: I got a fever, and the only cure is more cowbells!!
Sure is hell is light enough!! I'm handing this off to the guys that have run 9's. I would think with the T-56, the guy shifting the gears will make or break the run for the 9's.
Old Mar 8, 2007 | 06:47 PM
SuperZ's Avatar
Im gonna say no but tell me if Im wrong
Old Mar 8, 2007 | 08:16 PM
PowerShift408's Avatar
If you give us some power numbers, we'll be able to tell for sure.
Old Mar 8, 2007 | 09:14 PM
436rwhp 441rwtq dont know on spray, probably 550rwhp.
and I CAN drive it.
Old Mar 8, 2007 | 10:18 PM
venom ws7's Avatar
yes i think you can Rodney ran 10.1 with his cam only t.a and race weight-2950lbs
or maybe more he dynoed 440rwhp i think. So if you spray it you should be 9 for sure if you can drive like you said.
Old Mar 8, 2007 | 10:55 PM
yeah that thing just might on the spray
Old Mar 8, 2007 | 11:23 PM
Lythropus's Avatar
I haven't seen an LS7 clutch in the 9's...
Old Mar 9, 2007 | 05:38 AM
venom ws7's Avatar
^^^^^^^^ thats right you have to change that.
another thing do you have rear end?
Old Mar 9, 2007 | 03:01 PM
my rearend is fine, i got like 4 spares so i really dont care about that. won't an ls7 clutch hold like 600hp atleast?
Old Mar 9, 2007 | 05:27 PM
Lythropus's Avatar
Lots of the Z06 owners on corvette forum say it's difficult to launch, finicky, and doesn't hold very much. Most switch to a Textralia. 9's is not easy with a manual! Isn't the record like 9.3 or something like that? Oh and you won't do it on drag radials...
I say you definitely cannot with your set-up...but then again I've never been in the 9's so take it for what it's worth...
Old Mar 9, 2007 | 08:08 PM
67maro's Avatar
The record for a Fbody yes. But theres a Red 6 speed Viper built by UGR that ran in the high 7's.
Old Mar 9, 2007 | 09:12 PM
Whistler's Avatar
Sawzall and Welder Mod
How fast have you gone in the car before? What axle is in it? What kind of cage is in it? 2750 with an iron LS block must be a f-ing tin can. You've had it on a scale and that's the reading you got? It's easy to assemble parts that should run nines, but actually going to the track and doing it is another story.
Old Mar 10, 2007 | 01:03 AM
JRracing's Avatar
You would have to be on the money with the shifting. And I'm not sure about the ls7 clutch. You may have to eaz into it, then mash it on the spray.
That is a very light weight car, it should go 9's.
Old Mar 11, 2007 | 12:46 AM
Lythropus's Avatar
I'd like to take away my statement on drag radials, I was unaware that there are people running 7.4's in the quarter on 325/50/15 mt drag radials! That is crazy!
Old Mar 11, 2007 | 12:47 AM
Lythropus's Avatar
That is equally as crazy!
