Single Digit Club Running 9s or quicker? Damn!
what tranny to run 9s?
Old 04-30-2007 | 05:44 PM
paulgto's Avatar
Default what tranny to run 9s?
i have i have a stock 4L60E what do i need to do to it to run 9s or should i just get a power glide?
Old 04-30-2007 | 10:27 PM
Navy David SS's Avatar
What is/will be your set-up. All about power. Some run 9's and quicker with all different trannys. Also, converters are important. N/A, nitrous, force induction. All different, but still all the same.
Mine: T-400 - not stock
David
Old 05-01-2007 | 01:51 PM
wyndzer's Avatar
It took an RPM 4L60E for me
Old 05-01-2007 | 03:29 PM
Blownramair's Avatar
TH400 w/ brake
Old 05-01-2007 | 05:36 PM
paulgto's Avatar
Default with my 4l60e ?
what should i do to it to take the abuse also would a 3600 stall vig be ok?
Old 05-01-2007 | 05:37 PM
paulgto's Avatar
Default power
my car will be getting a turbo . dont if im gonna buy a kit or just make it myself>?
Old 05-01-2007 | 05:43 PM
97blkz's Avatar
I'm gonna try it in my 4l60E also.
Old 05-01-2007 | 05:46 PM
jimmyN's Avatar
i have a th350 if your interested. driveshaft and all.
Old 05-01-2007 | 05:50 PM
paulgto's Avatar
Default trans
thanks but either im gonna fix up what i have or just get a power glide
i dont want to be replacing parts and wasting money
Old 05-01-2007 | 07:42 PM
THE_SUPRA's Avatar
swap to an M6
do it supra style lol!
Old 05-01-2007 | 07:49 PM
97blkz's Avatar
Originally Posted by THE_SUPRA
swap to an M6
so he can replace clutches every month?
Old 05-02-2007 | 07:20 AM
Nautilus's Avatar
Hughes powerglide
Old 05-03-2007 | 08:49 PM
paulgto's Avatar
Default 4l80e?
are these alot better then the 4l60e?
Old 05-03-2007 | 08:56 PM
NoGamesLS1's Avatar
They are a th-400 with an overdrive
Old 05-04-2007 | 08:07 PM
paulgto's Avatar
Default 4l80e?
are they worth buying?
Old 05-05-2007 | 07:35 PM
396D1SS's Avatar
my mcleod twin disk is still holding strong?
Old 05-06-2007 | 01:41 PM
paulgto's Avatar
Default trans ?
i see aloy of people with 4l80e are they worth it?
Old 05-25-2007 | 01:11 AM
fenix999's Avatar
yes but a couple stupid mods MIGHT be needed to fit the car physically like BIGF*HAMMER, and also computer-wise you would have to get it to work with your stock computer as it does not recognize the 4L80e the same. They are worth it because its like having a bulletproof 4L60e just better. Stock one will probably handle 600-700hp easy and built ive heard and seen over 1000hp. All that and you still keep overdrive which is good for highway. The bad thing is that you have to get the electronics worked out and that they supposedly weigh alittle more than the 4L60e. But nothing major. hope this helps
Old 05-26-2007 | 03:44 PM
JDP's Avatar
JDP
swap to an M6
not supra style, but Joe Huneycutt style
Old 06-02-2007 | 04:59 PM
nahasapeemapetalon's Avatar
do not swap to m6 with big power, 4l80e
Quick Reply: what tranny to run 9s?
