Stock cube nitrous record?
#61
I'm still trying to get everything to work it's best. Last year I was leaving on a 200 shot and cutting 1.3X 60's but I was blowing through the converter, I sent it back and had it tightened up but I keep running into other BS problems, Hopefully in a few weeks it will all come together.
Pray to the Nitrous gods for me LOL.
#64
8 second mod
with my car i run 4:30's out back but i rev to 8300 rpm.
if you rev around 6800-7000 and plan on going 140-143 mph id say atleast 4:10's but id probably say 4:30's would be perfect. with those tires and 7000 rpm as long as your converter is right on you will go threw right on the money
what first gear in your glide? 1.8 i hope?
#67
GMMP with a BG Race Demon
NOYZEE, I have revved it to 7600 but it was an accident![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
There is no reason for mine to twist any higher than 7200, it's done doing it's thing by then.
On the dyno when I twisted it to 7600 I was running 160mph LOL, I know at the track it will be different.
Also, what was your torqu #'s with your little motor? Mine only made 631tq when it made 711 hp. I know the tranny and rearend will eat some but I still thought it would be a little higher.
Oh yea, it's a 1.82 glide and the converter should be perfect, it's setup just for my car, not just an off the shelf deal.
#68
8 second mod
put 430 in that thing and let it sing!!!!!
i forget my tq id have to look back. pretty sure it spun on the dyno and peak tq was down, but i wanna say around 655 but i will see if i can find the old sheet
#75
My car is set up for the 1/4 but the track that is close to me is 1/8 mile both of them....Just trying to see what it would do in the 1/4...Hopefully i will take the trip to memphis this year and try it out...turbo 400,325/50/15 mt drag radial,4.11 gear, should be good for 1/4
#76
Hopefully you can spin the motor up higher than I can. I'm running out of gear with 325's, and 3.89's on a th350. That's on the LS6 intake though. Hence the reason I'm making the switch the the victor jr.
I run 6.30's on a half assed 200 shot with the 10.07 so you can guess where the record will be. My best guess is that it will take some .70's-.80's to get close.
If it were an 1/8th mile record I would already have 5.13's in the car
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#77
I think i can get it with an 5.80 in the 1/8 with my sixty foot ..I got a progresser on the nitrous and it will 60 ft in the low 1.30's ....I am changing the springs now because when the motor was put togather the machine shop did not up grade the springs to a solid roller and it would pop at a high rpm.....So it might be even faster since the springs only had 110 pounds of seat pressure....
#78
8 second mod
5.80 will put you on the edge of 8's if the car is on the money. i forget what my 1/8 was on some 9.0-9.2 passes, but im pretty sure i went a 9.2x with a 5.82 1/8
a 5.90 will do it with the right set up.
good luck, i still see no one has done it yet. hehe
#79
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
