Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
motor combination??
Old Mar 6, 2009 | 07:59 PM
gyellow's Avatar
Default motor combination??
hey guys im looking for some help in the motor department fo rmy new build!! im lloking for mid to low 9's and still havent decided on a built bbc or built sbc! on top of what motor to go with i was going to run a decent nx shot (250-400) but recently have been thinking about throwing a procharger on there instead either an f1 or f2!! i was thinking depending on what motor i go with to have it running 450-550hp n/a then strap then blower on and hopefully get up to 800-900hp!! i know the f1 an f2 are capable of 38lbs of boost so i think the hp number is attainable!! now what motor would be best?? im prone to a bbc cause it would be easier to get the power rating i want n/a but will a sbc be cheaper?? what motor combination would be best for my goals??
Old Mar 6, 2009 | 11:49 PM
DeltaT's Avatar
A nice, all-forged 383 or 406 SBC would get you in the ballpark with a good set of heads, compression around 9.3-9.5, a Vortech YSi or Procharger F1 with a big front mount IC is a tried and true recipe.
I'm getting 632rwhp (~800 at the crank) out of my 383 with a Vortech T-trim and 12.2# of boost. Nice and reliable too.
But you need everything else in the car to be beefy enough to handle that type of power: tranny, rearend, cooling system, exhaust, etc. Expect to spend some money $$$$.
Jim
Old Mar 7, 2009 | 12:12 AM
gyellow's Avatar
are you runnng a normal sb or an lt style?? my concern with the bbc is first its gonna take up alot of space then trying to fit a huge f1 or f2 with intercooler and all the piping wuld b difficult
Old Mar 10, 2009 | 12:15 PM
NemeSS's Avatar
good ole 383 with spray and correct suspension setup should reach your goal.
Old Mar 10, 2009 | 01:44 PM
gyellow's Avatar
thats what im thinking but wont i be spending more to build a 500hp sbc than i will on a bbc?? im not trying to take the cheap way either it just seems smarter to do a bbc???
Old Mar 11, 2009 | 01:26 PM
NemeSS's Avatar
i would think thats its easier to drop in a sbc than a bbc in 4th gen chassis.
a few people here have done the swap, can work around stock kmember, same size as lt1, etc.
ZONE89RS, has a build thread /sticky.
ive always wondered y the sbc swap guys dont use pacestter lt LT1 headers. for the swaps?
Old Mar 11, 2009 | 04:29 PM
gyellow's Avatar
ya i sont know what ima do yet.. i have a bbc but i think like you guys said it would be easier to put a sbc in it
Old Mar 12, 2009 | 01:59 PM
NemeSS's Avatar
sbc would be the best option, if its gonna be a street type car, will save u alot of fabricating and parts sourcing, most of the sbc is readily available.
