383 stroker question and questimate
HEI
750 holley
rpm air gap
patriot freedom 185cc heads 72cc (mild portwork)
comp 12-423-8 224/230 .502/.510 (will this pull up to around 6000 rpm)
18cc dished pistons forged SRP
zero deck (should I)
200r4
about a 2000 rpm stall
Any guess on hp/tq
What head gasket do you guys recommend (thickness)
wanna keep it below 9.5:1
This is going in my almost DD 72 c10
http://www.compcams.com/Community/Ar...?ID=1945664039
I've talked with Scott about his and he really likes it. His 383 is a little pricey, but it shows what can be done. I would shoot for 10:1 compression. If you have to run 87 octane on ocassion, just dial back the timing a few degrees. I ran a 10.5:1 406 with trick flow heads that was fine with 92 and probably would have been okay with 89 octane. I currently have a 10.2:1 350 with pretty agressive timing that runs fine on 89 (I usually use 92 octane). I NEVER use any octane booster.
I'd say dial it up to 10 1/2 and run 93 in it all day. I don't think that combination of heads and pistons will get you there though. This is all good if you plan to add a super/turbo charger.
What is the LSA on the cam?
~Jim~
I missed this line the first time through. Whats the use/goal of the setup? DD with some pep or do you want whatever you can get out of the 383?
I wouldn't be worried about detonation with 10:1 and that cam. If you were at 11 or 11.5:1 to one then I'd say yes, but not at sub 10:1 but maybe I'm missing something.
What lift rockers will you be using?
~Jim~
You could always go with a flat top or dome piston and bump the compression up to 10.5:1 and spec out a larger cam to take some pressure off the engine. However, then you may be defeating the purpose of the build with a wilder cam.
At the very least I'd get in touch with another builder and tell him what you are doing.
Here is my disclaimer I'm not a engine builder so take this for what it is worth
Good luck
~Jim~
assuming you're bore/stroke is 4.030/3.75 and a 0.040" head gasket thickness and zero deck clearance, with 72cc combustion chamber and -18cc dish pistons that's coming out to be 8.96:1 compression ratio.
a piston with 5cc relief will result in 10.17 CR with a zero deck,
9.95 with 0.010" deck clearance, 9.74 with pistons 0.020" in the hole.
I would double check the measurements with your builder before you do anything, primary what your deck clearance is going to be and then choose the correct piston.
And you will need to know what rod length you're using, 5.7" or 6", to then figure out piston selection. I think you could be fine with the 72cc heads provided you size the pistons properly, and you might want to do some reading on forged pistons vs hypereutectic; I think you would be better off with hyp. pistons for being a mild daily driver NA setup. forged pistons are not always better than hyp. pistons.
I also agree with everyone else, shoot for as close to 10.0 CR, what will be most important is you're piston to head clearance a.k.a. quench, you want that as tight as possible, that is what prevents detonation or what let's you run higher CR without detonation. do some search on ls1tech and google for 'quench piston head clearance'
you also might consider 1.6 rockers, they are pretty much the norm as long as you have the piston to valve clearance with them.
What I mean is, a good piston that compliments a good head that compliments a good cam grind. The problem you are running into is you are stuck with incorrect pistons and now your compromising your top end to match an incorrect piston. If there is any wiggle room in the budget I'd look at the option of new pistons. Even if it sets you back some time. Do it once do it right. However, with the smaller CC heads you'll be able to play with your CR based on gasket thickenss more effectivley. (easier to raise and lower the CR)
Give another reputable builder in your area a call and see what he says about what you have. Doesn't hurt to ask!
Would you be against a super charger? That would compliment the 9.5:1 compression nicley!!!!
~Jim~
