budget 350
I'm looking to make 350hp at the wheels for my build. Stock shortblocks and vortec heads are abundant for me. Which block (350 2piece main seal, early 90s tbi, 94/5?-99? Vortec) makes best power with the vortec heads? All the builds I've read are with vortec heads on the 2piece blocks and they are apparently plenty capable of doing what I want but as always, more power is never a bad thing lol. Just wanna mmake sure I get the best combo, don't wana do everything and found it coulda been better 2 months later. think like this, I'm not building a motor just piecing one together.
That being said, I wish I had access to a few shortblocks and some vortecs.
The car made 320/306 to the tire 1 3/4 hooker super comps through a crimp bent 2.5 inch dual setup w/h-pipe and flow stopper 40series
with a crane 238/246 490/495 112lsa a set of hardened lite weight p/r's and promag 1.52's and around 10.2 : 1 compression
I ran the times in my sig with just 18 inch collector extensions.
So if I'm staying with roller cam, might as well just throw a cam in a complete vortec and then swap to carb. I've read its possible to make near 400hp this way. Is that true? Again, I don't know much about chevy stuff. I've been a dakota guy since I was old enough to drive but the low cast of chevy add ons is calling my name.just hoping to have a strong running, 350ish to the wheels that ill throw a 100 shot at. Trying to keep in mind I work at a junkyard and need to use that to my advantage.
If I worked at a junkyard, I'd be messing with ls series motors.
You will have to cut the seats for springs and guides for higher lift (.480 is max). Otherwise the reatiners hit the valve seals. Im runnin Lt4 springs and a flat tappit cam.
In a manual trans app i think your numbers are obtainable, but an auto with enough converter to support the cam you'll need... prolly not.
Here's the 2nd part of the build with an overview of what they did the 1st time around.
My truck weighs around 4500lbs.
