Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
lt1 cam in a sbc?
Old Jun 6, 2013 | 05:46 AM
TheDon619's Avatar
Default lt1 cam in a sbc?
Will a cam designed for the 93 lt1 non vented opti work in a tpi that im going to convert to carbed vortec. It is the cc503, i have it in my 95 formula and am happy with the way it runs in that and am willing to try it again sense i got one laying around. Ill have many questions over the course of the build. Build car: 1987 350 tpi 5 speed trans am.
Old Jun 6, 2013 | 08:14 AM
Stroked96Bowtie's Avatar
I don't believe so, the LT1 oil drive system is different than a small block chevy. Will possibly work if you are running an external oiling system (Wet/Dry).
Old Jun 6, 2013 | 08:43 AM
Rob WS6's Avatar
Yup itll work just fine, the only thing youll have to do is trim down the dowel pin. Theyre identical to the 87-92 roller cams except for the longer dowel pin.
Old Jun 6, 2013 | 10:05 AM
Paul Huryk's Avatar
Rob is 100% right about this - shorter dowel pin is the only difference...
Old Jun 8, 2013 | 09:37 PM
Big bird55's Avatar
do not forget you have to run an lt1 type timing change sprocket on the the cam being that the bolt pattern is a little different than that of an sbc block
Old Jun 10, 2013 | 10:52 AM
Rob WS6's Avatar
Any 87-92 style roller cam chain will work, you do not need an Lt1 specific gear set.
Old Jun 10, 2013 | 03:44 PM
Big bird55's Avatar
so the 87-92 cam sprocket has the smaller bolt pattern? just be sure to check it better safe than sorry
Old Jun 10, 2013 | 09:22 PM
Rob WS6's Avatar
Yup, all the gen I/II roller cams have the smaller bolt pattern than the pre-86 tappet cams.
Old Jun 11, 2013 | 03:35 PM
Big bird55's Avatar
well there ya go
Old Jun 11, 2013 | 10:08 PM
ZONES89RS's Avatar
In-Zane Moderator
As long as it has the factory type roller setup. It will not work for the older blocks. But 87-2002 roller blocks all day.
