engine 350 vortec cams 280h
Hi, I have a engine 350 vortec. I have installed cams comp 280H now I want to install a intake manifolds and carb edelbrock what is the right size and what is the intake manifolds is apprqopriate
http://www.compcams.com/Company/CC/c...x?csid=79&sb=2
engine 5.7 heads Vortec
injection computer
Cams comp 280h
I want to Conversion to carb
What is the appropriate cfm number carb
What is the appropriate intake manifolds
A dual plane intake made specifically for Vortec heads should work ok with that cam. Are you keeping computer control on the engine? What trans is in it. If you wan't to you can get a HEI or ready to run distributor and get rid of the ECM all together. But you will have to figure out your gauges. You'll need a way of regulating fuel pressure down as TBI injection is still a little too high for a carb. Unless your block was machined for a fuel pump push rod then you can run a manual pump. I run a 750DP on my vortec headed small block
