Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Using Alcohol In The Car ?
Old Dec 4, 2004 | 07:55 AM
1slowcar's Avatar
Default Using Alcohol In The Car ?
Anybody have any info or a good web site about the pros and cons ?? I want to run it (I think) save a lot of fab work for intercooler piping, water box and run cooler.. But I don't want to spend 10k to save 2k ... thanks
Old Dec 4, 2004 | 02:32 PM
Ls1LikeNoOther's Avatar
I run Methanol in my blown 57 chevy and I did last year when I ran Twin Dominators on my 540..Meth is a lot more constant,I personally love it,I hate using race gas anything I can run Meth on I do..
Old Dec 4, 2004 | 04:19 PM
WickEdSix98's Avatar
the good part about alcohol is it will make more torque. It takes more altitude change for the car to slow down, gasoline is about 200' change in DA for .01 and alcohol is around 600' change for .01. It costs about half as much as race gas. The bad part is you have to burn twice as much and it eats up your fuel system. With alcohol you have to change pumps/lines way more often than with gas. In the long run it probably costs more.
Old Dec 4, 2004 | 05:15 PM
You dont have to change your lines ever if you maintain them..I have never had to change a single line just take care of them.When you done putting fuel through it,spray wd40 in your lines take your fittings off spray everything down,dont let fuel sit in the lines and it should be ok...
Old Dec 5, 2004 | 03:33 PM
1slowcar's Avatar
Could you just run gas thru the lines and pump after a race like have a seprate tank and just let it run a min to wash the alcohol out ???
Do you have to change the oil more often ??
Old Jan 2, 2005 | 12:43 PM
99.9percenter's Avatar
Don't try this . When I was a kid the coppers always made me dump it out. Now a days I understand they put you in jail,and force peeps into church. Lots die after parties.
Old Jan 2, 2005 | 07:04 PM
I Run it on the street,its not that big of a deal as long as you keep up with the maintenance.And I know many cops in fact my gf's dad is Sheriff...
But when I cruise no problems ever from the cops.
Old Jan 2, 2005 | 08:16 PM
pwr2w8's Avatar
Um, I think streetbad was referring to drinking and driving, not using it as a fuel. The cops usually don't take too kindly to anyone with an open container of alcohol in the car....
Running your car on it, though, is a different story.
Old Mar 8, 2005 | 04:35 AM
Sandmann120's Avatar
Do a search on Ron's Racing. He markets a system dubbed "The Flying Toilet," it's a system that utilizes a 4 barrel manifold. It is a very simple system, that works very well. It would be a very good starter system, and works well as a blow-through setup.
Old Mar 8, 2005 | 07:34 AM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
alcohol also makes the car about 2-3 tenths quicker on average. As mentioned above, you have a little more to upkeep on your fuel system, and it will burn about 2 times as much as regular race fuel. It is deadly consistent though, as this is why a good number of super-class racers run it. They also make additives for better smell, as alcohol can burn the eyes (not as bad as nitro though).
Derek
Old Mar 8, 2005 | 07:29 PM
Lurch84's Avatar
We used to just flush out are sytems after every race dont even let it set over night or **** will be ate up like a **** found this out the hard way when it out my jets out to a diff size back when i raced go-karts.
