carbed sbc in to a 93-97
Originally Posted by litscot
I to am looking at doing this swap I've waited quite some time to do it and now that i've found others who have done and are doing this swap I'm in Iraq so hopefully this fall when I get home I can start on it, any help or unusual stuff you guy's could tell me about is great.what size wheels and slicks can you get under the 93-97's stock wheel well? Is it hard to fab a crossmember for a th350? Thanks
Originally Posted by lowbgtrs
What is a trigger and gutless distributor? Does anyone have a link?
And what exactly with the motor plates do for you?
Anyone?.......
Anyone?.......
I'm using front motor plates becuase the LT1 motor mounts only use the lower and rear top bolts from the original style motor mounts and the third bolt is towards the rear of the block. A conventional small block doesn't have the rear bolt towards the rear of the block so you can't use the LT1 mounts on a conventional small block. Plus my car started as a V6 car, so I'd have to change the cross member to use the LT1 mounts anyway.
what wires can i eliminate under the dash and in the engine bay? i dont need gauges or anything like that...only working lights and blinkers...i took out all the hvac boxes ect and bought a block off for the fire wall....also with a 4150 style holley950 hp what do i do for throttle cable and mounts?and you say lt1 radiator wont work with the sbc huh?thanks for the help...im about 1/2 way into the conversion now....
thanks alot
tony
thanks alot
tony
If you dont need gauges or computer than you wont need any of the wires coming out of the pass. side firewall. Lights are run off of the bcm (seperate computer from the pcm in the engine bay). For throttle cable i used one from an 85 z28 and enlarged the hole on the firewall. I used the lt1 radiator, but you will need flex hoses to route it properly. The lt1 radiator hooks up opposite of the older gm ones. (water pump attaches to upper driver side and thermostat housing attaches to lower passenger side) As for throttle cable bracket, i bought the plain bracket from autozone and bent the tab 180 degrees around so that it would line up straight with the carb. You may not need to do this on most carbs but i did on mine, holley 770 street avenger. Hope this helps.
yea ive gotton that stuff out as of yesterday...im trying to figure out what wires i can eliminate under the dash....i think im just going to leave a 1 foot pig tail off the fuse box and just run new wires through out the car for the things im gonne still power...
thanks for all the help....now you said i can use a ls1 radiator though and i dont have the backwards line problems right?
#32
Anyone running a front drive distributor? Something like the Jesel belt drive with MSD front drive or even Jesel's own front drive? I am leaning that way just so I dont have to worry about pulling the motor or fighting the cowl.
#34
LS1Tech Sponsor
we've always been able to use the stock throttle cable. I just mount the piece that clips onto the manifold to the cowl behind the wipers, then run the cable through the "screen".
And we've also used the front mount dist. w/belt drives, it's alot easier that way, just a ton more expensive than a conventional chain and distributor.
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
2016 Z07 Carbon
#38
im workin on almost the same project only its a 95 firebird... i never thought of clearancing for any of that...im also trying to turn it into a ws6 clone but carburated 350 will some of this stuff on your thread be close to the same?and yea wat is a trigger and gutless distributor? ive never heard of that on your pics of the camaro can you take that plastic piece off to acces the distributer?
