Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Engine Advice
Old Mar 5, 2005 | 08:53 PM
jarediocamaro's Avatar
Question Engine Advice
The motor is a 73 454. Compression is around 8.5 to 8.7 if it is still stock compression which I think it is. Whatever the cam is its tiny. It gets to about 5,000 RPM and its running out of breath. The intake right now is a Performer RPM which is overkill for the rpm I am running now. I am also running stock exhaust manifolds but Hooker competition headers are in the mail. Carb is a 600cfm edelbrock. What type of cam specs should I be looking at and what kind of carb should I be looking for? Im shooting for 6000 RPM. Oh and its a turbo 400 and a 3.55 12 bolt.
Suggestions
Old Mar 5, 2005 | 11:01 PM
68maro's Avatar
7 Second Club / STF Veteran
is it a complete stock rotating assembly with stock heads?
Old Mar 6, 2005 | 08:42 AM
CTSV05's Avatar
Well, before I decide on a cam, I would check to see which heads you have. If they are a normal oval port then you are in good shape.
I'm unsure when GM came up with the brilliant idea of "Peanut" ports, but even on a tow vehicle those sukk! They may have come after 73, but I would def. check.
Old Mar 7, 2005 | 12:53 AM
Yeah I ran my head casting numbers and they don't suck. One article described some of the desirable factory heads and mine was one of them. They are one of the larger oval port heads. Rotating assembly is stock, probably rebuilt a little while back, it runs nice. No peanuts here, that was my biggest concerns back when I first started looking at the motor.
Old Mar 7, 2005 | 10:48 AM
68maro's Avatar
roller would be best but if you want hydraulic look in the 250-265@50 range about 550-570 lift with a 110-114 lsa
Old Mar 8, 2005 | 12:14 PM
Wow that much cam? What type of stall converter you think I would need for that? What kind of RPM range can I expect?
Old Mar 8, 2005 | 07:25 PM
Lurch84's Avatar
Thats not much for a bbc, and trust me these guys know theyre **** wish id found this site long time ago.... Good luck with ur project.
Old Mar 10, 2005 | 06:03 PM
yeah these guys are awesome. Most tech services go way too conservative to be on the safe side. What kind of carb do yall think i should go for?
Old Mar 11, 2005 | 12:02 AM
CTSV05's Avatar
Well, if you are feeding this motor at 6000 rpm, then you need to be sure it can breathe, for a driver I'd go with an 850. If mileage is an issue then a 750.
But I like big carbs, I hate to hold a motor back on cfm.
