Stroking 355 to 383 weight
The weight difference will be negligable. The only real change will be adding a longer stroke crank and a different piston.
Unless you're going from an ultralight crank to a stock crank that is.
The only difference is weight of cranks. The block will actually weigh a little less due to clearancing for the larger crank. It all kind of balances out. Theyve got to be within 5-10lbs of each other.
