Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Fastburn Heads
Old Nov 23, 2005 | 01:11 AM
91Z28's Avatar
Default Fastburn Heads
http://purplesagetradingpost.com/sum...fo/heads1.html
Are those flow numbers on the Fast Burns legit? If so that seems like a killer head for the $$. Is a different header required for the exhaust ports? If those flow numbers are accurate I'm going to pick up a set and a new HSR lower manifold in the vortech pattern. I was told they were overrated, good for an easy 450 hp and not much else.
Old Nov 23, 2005 | 11:52 AM
orange88's Avatar
i was running them with 10-1 comp and a good size cam and 1.6 rockers getting 466 not even trying alittle bigger cam i could see 475 480 or more
Old Nov 23, 2005 | 06:38 PM
nick_s's Avatar
ive heard all sorts of differneces. SOme say thaose flow numbers were from the prototype heads and that the actual production heads flow around 245-250@.500 and around 180@.550
Old Nov 23, 2005 | 07:56 PM
AutoRoc's Avatar
I would agree with NICK, above. I went with E-Tec 200 heads from Edelbrock which are claimed to flow more than GM's. My E-Tec's flowed 230@ .500-.600 and with bowl work, 5 angle valvejob, no runner porting they flowed 260 with a 50+CFM gain on the lower lifts. For Sale I might add ET Performance ended up setting them up for 1.55" solid roller springs/valve and I never got around to using them. PM me if interested.
Oh and it seems every "vortec" manifold out there has TINY ports made to match the production IRON heads small ports. Ended up porting the hell out of my RPM Air Gap to match E-Tec 200 size ports.
Old Nov 23, 2005 | 08:24 PM
firefighter's Avatar
I'm getting ready to bolt up a set of the E-Tec 200's to a 383ci with a Holley Stealth Ram set up looking to get between 450-500 hp. We'll see in about 2 weeks.
Old Nov 24, 2005 | 11:48 PM
Tennessee Auto's Avatar
Mine went right at 240 stock. Now that there ported they flow 306. I had them flowed at a national head porting shop, and they flowed over 330. So it depends on the bench, and where the leaf blower is positioned.
Old Nov 26, 2005 | 01:04 AM
91Z28's Avatar
So the actual production head dies above .500? Looks like getting a cheap set of fastburns won't offset the 520$ to replace my HSR with a vortec pattern one anyway.
Old Nov 26, 2005 | 10:05 PM
nick_s's Avatar
Production head peters out on the intake around .500-.550. the exhasut keeps going into the mid-high 180's up to .600. Not to say you cant port them a tad and bring the numbers up, as stated by some other members. All in all, it isn't a bad head, 250cfm on the intake is great when compared to most stock iron heads flow around 200, but it all depends on your goals. If you already have an HSR base for pre 86 heads then step up to a set of afr 195's or 210's.
Old Nov 28, 2005 | 05:04 PM
superGMman's Avatar
There should be a sticky about the differences between the different Vortec style heads, Fastburn Heads, E-tec, etc. I think that there is alot of misinformation around about these heads which I have unfortunately been a victim of.
Old Nov 28, 2005 | 07:20 PM
You won't need a new intake. They have the old pattern intake bolt holes (pre-LT1) My motor has a Holley Strip Dominator on it. Its for the 55-87 style engine. The intake ports are raised a little on the heads, but it didn't matter since I had to open it up to match my ported heads.
My motor made 596hp with the fast burns. It puts down over 740hp rwhp on a 250 pills, with just a 352 ci engine.
Scott
Old Nov 28, 2005 | 09:26 PM
91Z28's Avatar
That is a shitload of hp for a 352. What are your cam specs?
Old Nov 28, 2005 | 10:28 PM
Its not real big, just a real fast ramp speed. Its 252 and .620 lift on a 109 plus 4. Heres a link to the video of the motor being dynoed. Its a large file, so just right click and save as http://site.tennesseeauto.com/projec...d/DSCF1793.AVI
Scott
