Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
sbc in 94 v6
Old May 23, 2006 | 06:24 PM
Eric95's Avatar
Default sbc in 94 v6
I tried a search but i couldn't find what i was looking for. Im about to start a project of dropping a 355 sbc into a 94 V6 camaro. Do they make conversion motor mounts for this swap and where can you get them? Also can I use the stock 5 speed? I would really like to keep the car manual.
Old May 23, 2006 | 07:03 PM
ROCNDAV's Avatar
I would think that it would be easier than dropping in an LS1. Doesn't most of the LT1 stuff line up with SBC? Why not drop in an LT1?
Old May 23, 2006 | 07:18 PM
TimTaylor75's Avatar
From this thread.
Here is a little list that I've put together for myself and you can search and find many more threads with useful information to help with your swap as well.
https://ls1tech.com/forums/small-block-big-block-chevy-specific/398775-4th-gen-carbed-350-swap-done.html – swap info
https://ls1tech.com/forums/small-block-big-block-chevy-specific/269010-carbed-sbc-93-97-a.html – swap info
https://ls1tech.com/forums/generation-iii-internal-engine/354351-how-remove-engine-bottom.html - How To Remove the Engine From the Bottom
http://community.webshots.com/user/badss97 - swap pics
http://www.michiganspeed.com/enginepull/index.html - engine removal
Old May 24, 2006 | 07:37 PM
Eric95's Avatar
i dont really want to use a motor plate, so does anyone know for sure about conversion motor mounts?
Old May 26, 2006 | 06:38 AM
Camaro396's Avatar
You can find swap crossmemembers and trans mounts on BMRs website. Get your wallet out and make sure its thick
Old May 26, 2006 | 02:18 PM
cwaldt's Avatar
You can make a stock K-member to work for a SBC/BBC. Just looks for links to my post under my screen name. Your job should be a little bit easier than my BBC install but most of the process will be the same.
Old May 26, 2006 | 10:09 PM
Strokinit383's Avatar
Many people dont know this, but you can use 5 out of the 6 bolts from lt1 motor mounts. Im going to try and figure something out for the 6th this summer so that i can have a back up if this tubular k member cracks, as many people claim theirs have. The 6th bolt is behind the driver side rubber mount on the bracket. On the lt1, they had a seperate bolt hole and the mount is extended backword to accomodate for the hole lost underneath the rubber mount. All the passenger side bolts work fine.
Old Feb 4, 2015 | 11:24 PM
nitrousjunkie87's Avatar
Default v6 to 5.3 engine mounts using the v6 cradle
What motor mounts or motor plate? Do I need to mount an LS1 into a 95 v6 camaro? Pics or links to buy/build them?
Old Feb 6, 2015 | 08:19 AM
v8sten's Avatar
lt1 k-member
lt1 mounts and the motor will bolt in
lt1 t56
lt1 headers
have a nice day
