BBC + Turbo=??
HAHAHHA.. nope.. sorry not on this one. I think BBC turbo deals are just a waste of time and money. With SBC/SBF- turbo motors making over 2000 hp with the right parts. that’s more then the avg guy would ever need or dream of. I feel another problem with BBC/turbo deals is. Its not that you can or will make more power with a BB over a SB when it comes to turbo. It’s really about making a well balanced combo. If the CI is to big the turbo will not be able to create boost without major lag and even after it does it will run past being efficient and not make the power a more balanced combo would. The one big advantage of a BB combo is having more head bolts then a SB motor does.
Wow im babbling now.. anyways… nope no pictures
Huh???
Not sure where you came up with that?
How about 1710 CID and turbocharging??
http://www.bcam.net/engines/allison.htm
As long as the Turbo is matched all is well and HUGE HP numbers will result
I just used the Allison as an extreme example of a BIG block.
http://www.nelsonracingengines.com/motors.html
What do you think?
If it was for strreet use at what speed will you get traction?
Huh???
its simple. the larger the hole to fill the longer it takes to fill that hole (or 8 holes in this case) and i am not saying you cant make big horse power but making big HP and making it WORK in a car with a transmission/converter that is a different story.
and as for that link.. 1710 ci only making 1475.. thats just straight SAD. Guys now adays make that with under 350 ci. but for the day that was good
What do you think?
RIGHT BEFORE YOU TAKE OFF!!!
Remember, these guys had to go fight with that motor and get back home. Pulling over was not exactly an option. At least not a very good one. The Germans saw to that.
Nope I did not, it has a bigger intake also and your point? still MORE volume to fill and the same turbo's on the market that can only fill so much volume so fast and the more volume to fill, the SLOWER it fills it.
Maybe you should go back to the video link above (http://www.nelsonracingengines.com/motors.html) and look at that 406ci motor they did for the editor of HOTROD that made 1100 hp on pump gas. They have to drive the car 300 miles - race it - then drive 300 miles again.
Which engine would be better to turbo and why?
Okay, it was a trick question. All three engines are about 400 CID. The one on the left is the 325hp 396 our of my '67 RS SS396 Camaro. It's a 396 + .040 The one in the center is a +.020 400. The one on the right is a stock bore '70 L78 from a Camaro that 's really a 402.
The point is that they all displace really close to 400 CID and will pump the same amount of air. It really does'nt matter if it's a big block or small block, forced induction will work about the same.
middle: small block good before I knew it`s a 400 block
thin walls and heating issues
right: bbc but you`ll change heads for better ones and intake seems a small dual plane (single rocks for forced induction)
now why left : bbc thick walls choose a canfield aluminum 320 or 360 cc intake heads (check for readyly available parts compatability or needing custom parts)or an iron Merlin 320 or 345 cc intake heads both with a single plane intake manifold from x-celerator to a victor 170 $ and 248 $ and it`s gooood
just an opinion.
