lifter stuck in bore
I know its a pain but the oil pump and the motor bearings may ( MAY ) have metal pumped throught them --- cleaning the pan out new pump and a good washing of the motor may fix it, pull two easy rod caps close to pump and last crank bearing cap to look if it was wrecked ( the bearing inserts )--- that was cast iron from the cam and hard steel from the lifter ( also ) if you have a snap gague with a mike or better a bore gague measure it ( the lifter bore ) to see if it egged shaped, and you can use a brake cylinder hone to clean up the lifter bore use mineral spirts ( paint thinner ) as a motor flush not gas, or just put it back together and hope it doesent do it again, we always epoxy a couple magnets to the valley of the block top to catch this sort of thing something to think about next time moroso sells a kit sbc bbc its like 15 bucks jz
if any others are stuck dont take them out till the cams removed will save the lifter bores tap them out in motor after its all apart jz
Guess what oil I put in my car right before the ticking started.
He said he had read that synthetic oil MAY not allow the lifter to spin in its bore. Just a thought.
