any info on the procomp heads?
http://cgi.ebay.com/ebaymotors/PROCO...16467306QQrdZ1
I'm looking to get the 210cc head by procomp. Not sure with the 190cc but the 210cc you need to run a +.100 longer valves and you should mach up the motor for longer pushrods.
.200 = 115in 114ex
.300 = 165 145
.400 = 209 164
.500 = 244 166
.600 = 255 168
These are with the out of the box valve job which leaves some to be desired. With a better valve job, some chamber unshrouding, and a backcut valve the low, and mid lifts come up 10-20cfm depending on the lift point.
Hope this helps.
