using a LS1 T-56 on a Gen I SBC
Can you use a LS1 T-56 on a Gen I SBC? I currently am running a 4+3 doug nash and have a spare LS1 T-56.
Do I have to change the input shaft or bellhousing?
the bellhousing bolts up you just have to leave one bolt out that doesnt line up, ive heard of it done before. as for the input shaft its longer for the ls1 you have to get a different one and the correct hydraulics
Originally Posted by cwaldt
T-56's aren't exactly cheap. It may be easier if he has the resources to change the input shaft.
If you convert to a LT1 style you will need to use a pull type clutch, if you leave it a modified LS1 tranny you can use a hydraulic TO bearing and a push type clutch.
Sure ya can.I am running a '99 T56 with the McLeod adapter and my stock '82 mechanical clutch linkage and clutch/flywheel components..No hydraulics here.
You can use your bell and the LS1 input shaft as is.You more than likely will have to run an extended pilot bushing from McLeod as well...I use the 8-1094.
You could always buy the SFI bell from Mcleod for the T56 to Gen 1 SBC. It comes with the block plate, bell, and aluminum spacer ring and will protect your feet at the same time in case there is an explosion.
I wouldn't swap to an LT1 input shaft. The LS1 T/O bearing will allow you to use a much larger selection of clutches for your car instead of limiting you to one design.
I would contact Tyler at www.t56kit.com for all your conversion needs. He helped me with my LS1 T56 swap into my BBC 66 Chevelle.
Kerry
Kerry
