Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
max c.u. for a b.b
Old Nov 22, 2006 | 05:40 PM
bob d.'s Avatar
Default max c.u. for a b.b
i need to know what the safe/ max displacement i can get from stock gm 454, before i need to move up to a dart block? is 540 possible? any help would be appreciated. thanks
Old Nov 22, 2006 | 06:51 PM
68maro's Avatar
7 Second Club / STF Veteran
i believe 505-510 but thats pushing it. if you want up to 588 get a gen VI block for 800 bucks. you don't need a dart block to go to 540.
Old Nov 22, 2006 | 07:54 PM
rocket22's Avatar
496 is the safest for a stock block,540 for a GenVI block,
Old Nov 22, 2006 | 09:21 PM
mrdragster1970's Avatar
6 & 8 Second Club
The max I have ever seen is 511", but I don't recommend it.
A 505" is very common, and strong. If the block is in good shape,
I recommend going with the smallest bore possible.
I don't remember ever seeing a 3/8th stroke in a stock block,
but that still only gets you 520"
The 509" is usually made with a big bore block and 4" stroke.
I also agree, if you don't need it, don't waste ~$2000 for a race type block.
I do have a brand new 557" I'm thinking about selling. Hint Hint
Old Nov 22, 2006 | 10:24 PM
JUICED96Z
Guest
Posts: n/a
All Aluminum 747ci
$54,995 Delivered!
This is it! Reher-Morrison's BIGGEST and BADDEST! 747ci All Aluminum 5" bore spacing MONSTER. This engine will put you up front no matter what or where you race!
This 4.750" bore, 5.250" stroke engine uses the 5" spreadport 14º CFE cylinder heads and takes the performance of the Big Block Chevrolet to the next level. It is tracked tested and Dyno proven to give consistent, reliable 1,450 Hp and 1,185 Ft/Lbs of Torque round after round.
Yeah its a BIG block.....just a Donovan Aluminum block LOL
I have allways been told to go with a larger bore and smaller stroke. This results in less friction due to a shorter stroke and a faster spinning rotating assembly. I red an article that one of Reher-Morrison's builders wrote and was talking about it. Just have to have a good ignition system to get an even and complete burn.
He also mentioned thats how the F1 guys build their engines also.
Old Nov 22, 2006 | 10:28 PM
rocket22's Avatar
I have heard about 828's in some nos pro mods.
Old Nov 23, 2006 | 12:07 AM
6 & 8 Second Club
Schmidt has a 760" Top Sportsman motor that is bad bad ***.
I believe it had 1550+ HP I'm actually saving up for one next year.
$56,000.00
I've seen 737" Pro-Mod's, and some outlaw guys a little bigger,
but an 800"+ HOLY _ _ _ _
You start with the smallest bore so after spending tons of money on block prep,
you can rebuild it a few times. Obviously if you are trying to use a stock block,
money is an issue. Besides you can't even use real heads on a stock block, valves will hit and you are missing 2 head bolts. Yes big bore, small stroke is usually best in drag racing. That is why we have all switched to big bore blocks. Which is .250-.375 over a stock 4.84 block.
Old Nov 23, 2006 | 09:30 AM
68maro's Avatar
fulton has a 870ci nitrous motor available. 5 1/4 bore space i believe
Old Nov 23, 2006 | 04:28 PM
smokin2002's Avatar
And i agree on staying to a 496 min. deff stroke wise. my rods had slight rubbing at the bottom of the cylinders. i just cant see going almost or .100 over without resleeving the block to touch 500ci
Old Nov 24, 2006 | 01:12 AM
rocket22's Avatar
Steve Kirk Jr has one goin in his pro mod for next year ADRL season,I think they have been running it in his 10.5 car.
Old Nov 24, 2006 | 07:51 AM
bob d.'s Avatar
thanks for the replies, i was curious on how big i could go before i couldn't use the stock block. this motor will be in a truck that see's deep water/ mud holes and local mud bogs. i want to build it as cheap as possible so i wouldn't be throwing away expensive parts after any accidental water ingestion. i wanted to run nitrous and maybe around 10:1 comp. obviously i'm looking to get the most h.p i can and still have a reliable engine. i would like to get 650 h.p or more, but i don't know what combo i should go for. would a 468 do it? i know forged pistons/ rods and crank will be a must. any other sugestions?
Old Nov 24, 2006 | 11:30 AM
6 & 8 Second Club
Compression = HP
Head flow & cam will limit & make the HP.
Obviously you will have to juggle strength & power if you're on a buget.
Power only, you would pick, highest compression, roller cam & best flowing heads.
650 HP with N2O will be easy, don't skimp on rods, crank & pistons. Good Luck.
Old Nov 27, 2006 | 09:12 PM
427TWINTURBO's Avatar
468 would do what you want it to do - would not go any bigger than 509 on stock block - 468 will make plenty of horsepower with the right heads & induction
