Converting my LT1
Don't believe anything in there
From this thread.
Here is a little list that I've put together for myself and you can search and find many more threads with useful information to help with your swap as well.
https://ls1tech.com/forums/small-block-big-block-chevy-specific/398775-4th-gen-carbed-350-swap-done.html – swap info
https://ls1tech.com/forums/small-block-big-block-chevy-specific/269010-carbed-sbc-93-97-a.html – swap info
https://ls1tech.com/forums/generation-iii-internal-engine/354351-how-remove-engine-bottom.html - How To Remove the Engine From the Bottom
http://community.webshots.com/user/badss97 - swap pics
http://www.michiganspeed.com/enginepull/index.html - engine removal
Not so true. 4l60e's can be made to not need a PCM to controll it. For this to work you would need to have it converted over to a vacuum modulator. Once this is done it no longer needs a PCM.
-Dave
