Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
lets talk heads
Old Jun 29, 2007 | 03:34 PM
BigBlock10's Avatar
Default lets talk heads
well guys i am in the market for new heads the motor i will be puting them on is a sbc 355 with a procharger d-s1. the motor will not be taken past 6500 RPM. now the problem is what brand to go with, there is about a million diff brands out there. AFR, world, brodix, DART. thats just to name a few, what would you guys go with? for alum heads in the $1300 range
thanks for the time guys
DEREK
Old Jun 29, 2007 | 04:25 PM
blown454ss's Avatar
trickflow
Old Jun 29, 2007 | 06:30 PM
merriman44's Avatar
AFR's new eliminator series seems to be a good head. If I was you I'd hit them up and see what they can do for you. I'm going to use their 180cc head.
Old Jun 29, 2007 | 09:13 PM
Ryan02SS's Avatar
AFR Eliminator's all the way.
Old Jun 30, 2007 | 01:02 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Canfield makes nice aluminum SBC heads as well, I have a set on my Nova's 383 powerplant.
Derek
Old Jun 30, 2007 | 02:11 PM
1997bird's Avatar
Dart's new platinum series aluminum heads are a great lower cost cylinder head that utilizes wet flow technology. http://www.chevyhiperformance.com/te...ads/index.html
Old Jun 30, 2007 | 02:38 PM
vanilla89's Avatar
Pro Top Line 235's or Dart Pro1 230's are the best untill you go offset rockers or 18*...IMO
Dont get cought up in all the "AFR" hipe,IMO it's over priced junk
Old Jun 30, 2007 | 03:26 PM
capn smokey's Avatar
AFRs eliminators are awesome heads but the trick flows can make some sick power too, I would check out some super chevy and hot rod write-ups on them.
Old Jun 30, 2007 | 03:40 PM
1997bird's Avatar
AFR makes quality cylinder heads! They do cost more than most heads and have a lengthy delivery time (usually if you order directly from AFR). Those are about the only down falls that I have seen with them.
Old Jul 2, 2007 | 11:03 AM
BigBlock10's Avatar
cool, thank's for all the info guys
Old Jul 3, 2007 | 02:54 PM
AutoRoc's Avatar
Is this a street motor? Even with low RPM, will there be a lot of boost? Is it cammed for 6500 max or does it have stock rods/valvetrain? Auto with high stall or manual trans? if AFR195 Eliminators were avaliable I'd try them, assuming they don't cost more than their old stuff.(less than $1500). AFR210's or a Dart 215cc might be nice too. All depends on if you are looking to wring out a lot of power or just want something torquey...Can you get cam specs?
Old Jul 3, 2007 | 03:34 PM
ulakovic22's Avatar
$1300 each or for the pair? I'm going with a set of RHS heads on my BBC project.
