89 ta 305?
Dustin
60' ... 1.665
330' ... 5.072
1/8 ... 7.971
mph ... 84.36
1000' ... 10.505
1/4 ... 12.665
mph ... 103.98
Does the 12 second 305 run on pump gas?
J/K, you ever wonder what 80 more cubes will net you? I mean you really have no reason not to buile 383+ cubes now day, if your 305 broke would you step it up then?
ok, i'll be nice and post it all here...i got it in my vB garage on thirdgen.org so it's not difficult to copy and paste.
specs of my 1990 Ralley SportCoupe:
ENGINE SPECS
-1985 305 block .030" over
-Eagle cast 3.48" crank
-Ohio Crankshaft forged rods
-10.2:1 compression
-comp 280H magnum camshaft, 230*/230*, .480"/.480" 110lsa
-comp pro magnum 1.52:1 roller rockers
-#416 casting 305 "HO" heads. mild bowl blend, backcut stock valves, comp 981 springs, screw-in studs and guide plates, milled to 53cc combustion chamber volume.
-holley street dominator intake manifold p/n 300-36
-holley 650 double pumper modded and tuned by me
-hedman longtube headers
-dual 2.5" mandrel bent y-pipe into single 3.5" that dumps infront of rearend. listen: http://youtube.com/watch?v=_93-ig9Wvj4
-ignition is supplied through a mildly modified stock HEI with Accel Supercoil
FUEL SUPPLY
-stock tank fitted with -8 male fittings in bottom left corner
-aeromotive street/strip pump with -8 line from tank to regulator
-aeromotive street/strip return style regulator
- -6 return line for now, will go to a -8 soon.
TRANNY
-red neck performance long tailshaft th350
-36 element intermediate sprag
-reverse manual valve body
-9.5" 4100 stall red neck performance torque converter
-red neck performance transbrake
REAREND
-moser bolt in 9"
-4.56:1 gears
-full spool
-31 spline axles
-areospace components drag brakes
SUSPENSION
-Jegster bolt-in sfc's that i welded in and added extra bracing, triangulating the underside of the car
-BMR weld-on lca relocation brackets (second most important suspension mod after sfc's)
-Lakewood rear lca's
-Spohn non-adjustable panhard rod
-Jegster non-adjustable torque arm
-v6 springs, 1 coil trimmed off front, 1.5 off rear
-solid motor mounts
-stock v6 front struts from 1990, ~220K on them and working great for what i need!
-monroe replacement rear shocks
-front sway bar delete
-IROC rear sway bar w/ poly endlinks
-DS loop
WEIGHT REDUCTION
-s10 manual steering box
-complete HVAC delete
-front bumper support delete
-complete emissions delete
-83 z28 'glass hood
-Mickey Thompson ET Drag Wheels, 15x8 w/ 4.5" backspacing out back and 15x3.5 w/ 1.75" backspacing up front. running 29x9 hoosier slicks compound D06 out back and 26x7.5 mickey thompson sportsman front runners.
-ACS front carpet piece, only weighs like 10lbs total
-fourth gen front seats, no power anything, on thirdgen seat tracks...another 10lbs or so...yeah that much!
-car weighs 2975 w/ full tank of fuel and w/o driver.
this is all before any of the mods i'm doing this week for this weekend. i'll post up results after i determine if what i'm doing is worth a crap, lol!
What you think about it in a VERRY often driven RS?
Maybe....with a 250 shot.
