Carb tuning help...please
Hydrocarbons in PPM idle standard 450/ idle reading 514
carbon monoxide in% loaded standard 3.75 loaded reading 5.69
The guy sai my car is running to rich which i new when i got that car is was just by the smell so...... how do i tune a 650 edelbrock to lean the **** out of it? thanks!
If not, you can hook up a narrow band O2 sensor to at least dial in the idle/light throttle.
Do some google searching for a simple O2 sensor setup that can be monitored with a common digital multimeter.
You can get a much better tune with any carb if you can tell exactly how any of your
tuning changes are affecting the exhaust readings.
Look at any carbureted car that makes serious power...You won't find an Edelbrock/Carter AFB/Quadrajunk there. You'll find something based off the Holley double pumper's design.
The jets and rods are easy enough to change, and yes, probably easier than a holley. You dont even have to drain the bowls to change them.
The only bad part about them is you have to buy a whole tuning kit for them, as opposed to individual parts.
The metering rods and springs act as the power valve does in a Holley. The only difference being that at idle, or slightly off idle, the metering rod is in the jet, so changing to a larger metering rod can lean it out some at part throttle.
HA! I will agree on the Carter and Quadrajunk, but not the Edelbrock! Its all preference, but by far the 2 best are Holly and Edelbrock. If you tune your Edelbrock in, you can make awesome power! Its not all in the carb either! Its in the cam, heads, valves, intake, and so on. You can make huge power with either carb. You also need to make sure you get your cfm correct for your motor too. So many variables. Anyways, lol so much said for just saying I like Edelbrock lol. I dont mind Holly either!
