Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Intake/Carb
Old May 31, 2008 | 03:55 PM
UpOnOne781's Avatar
Default Intake/Carb
Hey guys im trying to find a good setup for an intake and carb combination. I have vortec heads and im looking for about 450 horse at under 5500 rpms. Any suggestions for a good setup?
Old May 31, 2008 | 08:41 PM
ZONES89RS's Avatar
In-Zane Moderator
Well, if you have 350 cubes or 355, a air gap inake and a 650 carb from holley would net you that at about 6300 with the right cam, maybe 425. If you have a 383 you might be able to get it around 5700 RPM, also with a air gap and 650 carb, the 383 would like a 750 a bit more and it would work verry well. I like the XE288HR cam from comp personally.
Old Jun 1, 2008 | 09:33 PM
UpOnOne781's Avatar
thanks for the info. I got a comp cam 270H in there. And its a 355. i had it bored .030 over.With that setup i should get at least over 350 horse right?
Old Jun 1, 2008 | 09:56 PM
ZONES89RS's Avatar
In-Zane Moderator
At the flywheel, it is possible, might be around 370 even. I would never use a cam that small though.
Old Jun 1, 2008 | 10:08 PM
Drumer919's Avatar
What head work do you have done and what is your CR?
Old Jun 2, 2008 | 05:56 PM
UpOnOne781's Avatar
i just got vortec cast iron 64cc heads. My CR is 9.35:1. And a holley carb should fit onto the edelbrock intake right?
Old Jun 2, 2008 | 08:08 PM
ZONES89RS's Avatar
In-Zane Moderator
An Edelbrock intake that is made for vortec heads it will.
Old Jun 5, 2008 | 10:10 PM
UpOnOne781's Avatar
im lookin at one of the edelbrock carb/intake kits, should i buy the combo kit or get them seperatly? Im building on a budget...
Old Jun 5, 2008 | 10:24 PM
RAGENZ28's Avatar
Summit has kits, I'd get a regular holley with a dual plane intake.
Old Jun 5, 2008 | 11:03 PM
UpOnOne781's Avatar
is there going to be a big difference between the summit brand intake and a performer rpm intake?
Old Jun 6, 2008 | 01:08 PM
MrOverkill's Avatar
Just the quality isnt quite as good but decent, its a copy of an Edelbrock just like all of Professional Products intakes which are Chinese knockoffs.
