Who has a BIG CUBE Firehawk? Post 'em up!
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Post your year, transmission, build #, displacement, Heads, Camshaft, exhaust, and power adder if applicable ![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Mine is a 2001 D&D Performance M6 #89
TSP 402 or 6.6 L 11.2:1 CR with -10cc pistons
Currently running Ported LS6 Heads with a Vindicator Cam
Kooks 1 7/8 stepped to 2" Headers with a 3 1/2" Y-pipe going into a Corsa
FAST 90 ported with a Direct Shot
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
my 1995 firehawk #584. T56, 385cu.inches of LT1 anger fed by an intercooled rear-mount STS/LEP T-67 turbo. custom LEP cam, ported & polished stock heads. stock'ish exhaust fully wrapped.
http://www.youtube.com/watch?v=YVGgN7hZVSI
![](http://i33.photobucket.com/albums/d76/firehawk584/DSC_1617.jpg)
![](http://i33.photobucket.com/albums/d76/firehawk584/IMGP1508.jpg)
I have an 02 hawk #691 with 9700 miles.
MID 427
Coated Diamond Blower pistons
AFR CNC 225 heads
8.9:1 Compresssion
Callies Magnum XL Crank
Callies Rods
Comp Cam and pushrods
Lunati Lifters
Melling Oil Pump
Kooks 1 7/8" stepped 2" 3.5" Collector
4" Exhaust
ATI Procharger D1SC
Custom Crank pulley
RR blower pulleys
BeCool Radiator
Evans high flow WP and Coolant
M6
![](http://i54.photobucket.com/albums/g113/blkhwk/Test/100_0833.jpg)
![](http://i54.photobucket.com/albums/g113/blkhwk/Test/100_0976.jpg)
MID 427
AFR CNC 225 heads
8.9:1 Compresssion
Callies Rods
Lunati Lifters
Melling Oil Pump
4" Exhaust
ATI Procharger D1SC
Custom Crank pulley
RR blower pulleys
BeCool Radiator
M6
![](http://i54.photobucket.com/albums/g113/blkhwk/100_1654.jpg)
I know this is a really old thread, but i think it would be fun to resurrect it and see if there are any people out there these days that have gone ahead with their builds.
My Hawk:
2000 Firehawk #668.
This car is 1 of 2 black hard top firehawks produced that year. Currently has ~63k miles on the body, and ~13k on the engine.
Engine/Drivetrain Modifications:
1. 402ci LS2 block
2. Callies Magnum crank
3. Callies Compstar rods
4. Diamond Pistons
5. Vindicator Cam 240/244 .608/.596 112
6. High flow oil pump
7. Ported AFR 225 heads.
8. Ported LSX 90mm intake
9. Nick Williams 90mm throttle body
10. Underdrive pulley
11.Kooks headers and Y pipe, no cats
12. SLP Dual Dual exhaust
13. 10 bolt axle w/ 4.10 gears and TA rear girdle
Suspension Modifications:
1. Ground Control coil overs on front with 600lb springs, rear springs are custom straight 200lb rate springs with Ground Control height adjusters
2. Koni Double Adjustable shocks
3. Aluminum rear lower control arms with quality rod ends
4. 35mm hollow front sway bar
5. 22mm hollow rear sway bar
6. Aluminiun adjustable rear panhard bar quality rod ends
7. Sub Frame Connectors
8. Drive shaft loop
9. Tubular K frame
10. Tubular torque arm
11. Brake ducting from lower spoiler to rotor hats
12. Hawk pads in front and rear.
13. LG Motorsports caliper relocation brackets
14. C5 Corvette rotors.
Wheels/Tires Modifications:
17X10.5 280 Motorsports with Nitto 315s all around
My Hawk:
2000 Firehawk #668.
1. 402ci LS2 block
4. Diamond Pistons
8. Drive shaft loop
9. Tubular K frame
