High Flow LS2 and LS3/7 Injectors All Flow Matched
LS1TECH Sponsor
We now are offering high flow injectors for Just about any LS based vehicle in need of a bigger fuel supply for all that additional horse power you have added or are going to add.
We now have available GM factory re sized injectors for LS1/LS6, LS2 and LS3's that are flow matched and upgraded to support 750 + horse power applications.
LS2 72lbs:
$325.00 shipped - lower 48.
Perfect for any LS2 car in need of more fuel with no adapter's needed, will also work with LS1 and LS3 but will require either spacers or injector connector adapters. Able to support up to 750 + hp. The 60lbs is based on 3 bar, or 43.5 psi, where as LS cars run 4 bar at 58psi, which on LS fuel pressure of 58 is 72.25lbs. If needed we may be able provide the adapter kit based on your specific application.
![](http://i28.photobucket.com/albums/c205/juicedss262/IMG_2709.jpg)
LS3 72lbs:
Perfect for any LS3 car in need of more fuel with no adapter's needed, will also work with LS1 and LS2 but will require either spacers or injector connector adapters. Able to support up to 750 + hp. The 60lbs is based on 3 bar, or 43.5 psi, where as LS cars run 4 bar at 58psi, which on LS fuel pressure of 58, is 72.25lbs.
![](http://i28.photobucket.com/albums/c205/juicedss262/IMG_2711.jpg)
We typically have LS1 and LS6 injectors in the 58lb size but are currently out.
LS2 72lbs:
LS3 72lbs:
Last edited by JeremyF; 02-02-2010 at 04:46 PM. Reason: Do not carry 72lb LS1/6 injectors.
LS1TECH Sponsor
LS2 72lbs:
LS3 72lbs:
LS1 48lbs:
$300.00 shipped - lower 48
![](http://i28.photobucket.com/albums/c205/juicedss262/IMG_2446.jpg)
We can provide an injector flow rate slope for these injectors.
LS2 72lbs:
LS3 72lbs:
LS1 48lbs:
LS1TECH Sponsor
We have plenty of LS1, LS2 and LS3/7 "shorty" injectors available.
Please call us at 813 476 7364 for Visa, MC, and AMEX payment, or you can Paypal at fastprom@tampabay.rr.com
If you use Paypal, please include your shipping address.
Thank you
Thank you
LS1TECH Sponsor
Thank you
Thank you
