TTP Stage 3 Equalizer Heads/Cam Package Specials
Old 10-01-2004, 12:54 PM
TTPMatt's Avatar
Default TTP Stage 3 Equalizer Heads/Cam Package Specials
Put your names on the list for the next shipment of AFRs!
Here is the package for the f-body/y-body:
TTP AFR 205cc CNC Heads with Dual Springs, Titanium Retainers - Finish Ported/Polished by TTP
TTP Equalizer V.2 Camshaft
TTP Hardened Chromoly Pushrods
Rollmaster Double Roller Timing Chain
SVO 30lb Injectors
NGK TR55 Spark Plugs
GM Steel Headgasket Kit
(2x) GM Headbolt Kits
(2x) AIR Gaskets
(1x) EGR Gasket (If needed)
GM Timing Cover Seal
GM Timing Cover Gasket
(2x) GM Waterpump Gaskets
Installation
LS1 Edit Full Custom Dyno Tuning (Part throttle, wide open throttle, custom timing map, removal of engine codes)
$4709.95 (Add $100 p/s rack surcharge for Corvettes)
Options:
LSX 90mm Port Matched Intake Manifold with FAST 90mm Throttle Body - $1465 Installed (Add $285 for TPIS t/b on Corvette)
Meziere Electric Water Pump with Relay - $600 Installed
Kooks 1 3/4" LTs with 3" ORY - $1000 Installed (Add $260 for Cats) (Add $200 for Corvettes with X-Pipe)
This package just made 482rwhp/418rwtq through a 2002 Camaro M6 with LSX 90mm, Mez Electric W/Pump, 4.10 gears, SLP Loudmouth, Kooks 1 3/4" LTs, ORY.
This package also made 474rwhp/429rwtq through a 2003 Z06 with Stock LS6 Intake, Stock Throttle Body, Mez Elec Water Pump, Borla Stingers, Kooks 1 3/4" with OR X-Pipe.
You can give us a call at 973-340-4069 to schedule an appointment.
We also offer this package through our New England distributor in Massachusetts, Don Kinder (Slowhawk) @ DEZ Racing. Call for more information regarding NE installations.
Old 10-01-2004, 06:44 PM
JasonG's Avatar
Dyno #'s look great. Just wish I could afford that much to put into my car. I've sent you a couple of PM's and left a msg at the shop for ya about some things. Hope to hear from ya soon.
JasonG
Old 10-01-2004, 09:27 PM
TTPMatt's Avatar
Jason: Im going over final pricing for your quote you'll hear from me tomorrow
Old 10-03-2004, 12:05 PM
WAHUSKER's Avatar
Matt,
I want more info on your Stage 2 heads. What is your warranty? I assume they've been ported & polished to achieve 300 flow. Are they milled to get the 10.7:1 comp? I have a GM Hot Cam with 1.8 Harland Sharp rockers, along with Manley springs & pushrods & a RollMaster dbl chain. And I have PPC headers & an LSX intake. Would these work well with my setup? I drag race & want to run some open road races too.
Mark
Old 10-03-2004, 02:54 PM
TTPMatt's Avatar
Sure would. You'd basically be buying the AFR 205cc heads from us, however if you sent us your intake, we could port match it to the AFR's and achieve more flow. The Hotcam is has some decent torque so the heads would be a good match. I don't know if you'd achieve maximum HP with that cam, but the torque should definitely rise. You'll also see at least another 5+ hp/tq from port matching to your intake. I assume you have the 78mm LSX.
You'd be looking at:
AFR 205cc Heads $2182 free ship
Port Match Intake to Heads $250.
Old 10-03-2004, 06:04 PM
WAHUSKER's Avatar
Um, I was actually inquiring about the regular LS1 Stage 2 heads that are on your website on special now for $1395. I know the AFR heads are the bomb. I wish I could afford them, but I have to buy a roll cage too. So, can you tell me how those would do? (besides being not as good as these, but compare them for me if you'd like)
Thanks Matt, and sorry for the confusion.
Old 10-04-2004, 11:06 AM
TTPMatt's Avatar
We no longer offer those heads. Sorry for the confusion on my end.
Old 10-04-2004, 01:14 PM
69firebird's Avatar
how much for the parts not installed?
Old 10-04-2004, 02:25 PM
TTPMatt's Avatar
We do not sell our cam without installation, so I cannot offer you the cam. Everything would be about $3050 without the cam and tuning. Then add in the options if you want.
Old 10-04-2004, 02:27 PM
69firebird's Avatar
why wont you sell it without install? Im not going to get it cam carded or anything this is for my stroker motor
damn
never mindt hen
Old 10-04-2004, 02:44 PM
TTPMatt's Avatar
Sorry, just our policy. We can sell you a G5X2/3 series. Lou's cams make awesome power too.
Old 10-05-2004, 05:12 PM
BLASTER's Avatar
Matt,
Will you be doing a similar package with the 225s? I am interested in the 225 heads with hand finishing/milling with a port matched intake. Thanks
Old 10-07-2004, 10:21 AM
TTPMatt's Avatar
BLASTER: Yes we will be.
Old 10-11-2004, 04:26 PM
CHAMP02SS's Avatar
What's the difference b/w the 205's and the 225's?
Old 10-12-2004, 12:08 AM
riddler's Avatar
Are your prices for Lou's cams better than buying it right from Lou??
Old 10-12-2004, 10:04 AM
TTPMatt's Avatar
Champ: The castings are the exact same except the 225's has a different style intake port (Obviously 'larger').
riddler: Honestly I'd call Lou @ LG and get the cam straight from him.
Old 10-13-2004, 01:10 PM
CHAMP02SS's Avatar
Thanks Matt. How much more power(hp) will the 225's give over 205's. What is $ diff over the 4,600 and change for the 205 package deal you are currently offering? I am looking to get on or above 500rwhp. Matt please call me at 203- 218-1800 at your convenience I would like to discuss options and prices to get me up to the 500+ rwhp with my current mods plus heads and cam. Thanks John
Old 10-13-2004, 05:24 PM
TTPMatt's Avatar
Champ: Ditch the cats... Pickup the LSX 90mm, Meziere Water Pump, possibly add a cutout and we will be as close as possible to 500.
I'll give you a call tomorrow running out of the office now to take care of something.
Old 10-27-2004, 10:04 AM
TTPMatt's Avatar
t t p
Old 11-30-2004, 10:51 PM
CHAMP02SS's Avatar
Default Price Match Slomaro
Matt did you see the deal slomaro in Houston is offering for an AFR 205 head and cam package? He has it listed at $3750. That sounds too good to be true. Anyway you can come close to meeting or beating that price. If so schedule me in. I figured it couldn't hurt to ask. By the way any testing on the AFR 225's yet?
