Octanium - The Most Powerful Race Fuel Concentrate Available!
With the movement toward ethanol use in today’s vehicle’s and the continued decline in gasoline quality, the need for a thoroughly developed and tested octane enhancer that provides today’s high performance gasoline powered vehicle with the consistent, stable higher octane fuel that it requires is at an all time high.
Recognizing this need, we began the process in early 2006 of developing a commercially available octane booster that would a) address the above needs, b) provide verifiable lab tested results and c) be applicable to a full spectrum of vehicles including but not limited to cars, trucks, SUV’s, watercraft and motorcycles. The end result of this extensive research and development effort is Octanium, the most cutting-edge octane enhancer ever manufactured.
While there are several other commercially available octane boosters available presently, the results from them are limited at best due to their chemical composition and the lack of verifiable octane enhancement provided by each. Ocatnium differs from others in the market in that the chemical composition has been developed, tested and proven to raise octane in gasoline (R+M/2 formula) a full seven points or higher (ie, from 93 into 100 Octane) dependent on the dilution of the product in a tank of unleaded gasoline.
Octanium ………
- Reduces detontation and pre-ignition in all gasoline powered vehicles resulting in increased horsepower and torque and consistent engine performance. Results confirmed by independent laboratory testing.
- Race fuel concentrate – provides ordinary unleaded gasoline with the properties of a racing fuel.
- Safe for oxygen sensors and catalytic converters.
- Reduces hydrocarbon and carbon monoxide emissions.
- Prevents stalling, hesitation, knocking and pinging in all gasoline powered vehicles.
- Cleans injectors, combustion chambers and prevents valve sticking.
- Improve’s quality of today’s oxygenated fuel and corrects lean conditions caused by ethanol blends.
Dyno testing on a supercharged 2005 C6 Corvette showed a 30 rwhp improvement with no additional changes as the vehicle was experiencing significant knock retard prior to the introduction of Octanium to the fuel system. - Dyno Sheets are available for anyone who'd like to get a copy - just PM us!
For complete details and ordering, please click on either our banner or button ad or visit us directly at www.octaniumpower.com
Thank you for your interest - we look forward to serving your needs as a sponsor of LS1Tech for years to come!
Octanium ………
Nearly impossible. It would take a straight race fuel to achieve that goal. This concentrated additive is good up to 100 octane or slightly over and not much more. We've done extensive testing with the product and the more you add (past 64 ounces) the closer you get to the point of diminishing returns. It is safe to add Octanium to as little as 5 gallons of pump gas.
This product has also been proven to improve the octane level and performance of unleaded racing fuels.
Thanks for your interest.
Originally Posted by TARZAN
Out of curiosity...how difficult would it be for your product to take 93 octane and make 110+?
-Will
-Will
Originally Posted by PAGregSS
Sounds like it works great on improperly tuned vehicles.
I use vp motorsport 109 oct How much of a boost in oct would i get by adding one bottle of your product to 10 gallons of this fuel?
There is no technical data regarding delution rates of the product. It only states it will raise it to 100 oct. Is that one bottle per 10 gallons of fuel? will it raise it 4 points in 20 theres nothing but a bunch of blah blah blah on the website
