Introducing The PRC CNC Ported LS7 Cylinder Head!
Guys we're proud to announce after months of development & testing that the all new PRC LS7 cnc cylinder head is complete! The PRC LS7 cylinder head was built for big cube ls engines wanting the maximum possible cylinder head flow for the dollar! With 390+cfm air flow capability this all new cylinder head is set to be the leading head choice for these new big cube LSx & LS7 based engines.
Extensive valve testing has resulted in an all new hollow stem valve option to help keep both price & valve weight down! No longer will it take $3000 to build a LS7 based cylinder head for your big cube project!
Current price on the base PRC LS-7 Cylinder Head is $1699.99 with standard stainless REV valves & stock LS1 springs. Upgrade to the all new PRC hollow stem valves & PRC double spring kit & the complete cylinder head kit is only $2199.99!
Here's the options available with these cylinder heads:
Stainless Valves / Titanium Valves / Hollow Stem Valves
Standard Spring / 928 Comp Springs / PRC Dual Spring Kit
Here's Flow data for you guys!
LS7 Int LS7 Ex PRC LS7 Int PRC LS7 Ex
cfm cfm cfm cfm
.200 161 114 168 119
.300 227 171 244 179
.400 291 193 304 207
.500 330 203 345 219
.600 351 209 375 229
.700 359 390
Check out additional pics & info @ http://texas-speed.com/shop/item.asp...d=823&catid=40
![](http://www.precisionracecomponents.com/ls7cnc1.jpg)
![](http://www.precisionracecomponents.com/ls7cnc2.jpg)
![](http://www.precisionracecomponents.com/ls7cnc4.jpg)
cfm cfm cfm cfm
.700 359 390
![](http://www.precisionracecomponents.com/ls7cnc5.jpg)
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Thanks guys!! We worked really hard to make this thing happen!
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
Not at this time, currently we're only working on stock castings.
Thanks
Jason
Thanks
Jason
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
What size are the combustion chambers? I'm really debating whether I will need the extra 2 bolts per cylinder. I'm shooting for 600-650 rwhp NA out of a 441 ci LSX block. I know the heads can handle that, but I would also like to hit it with a 300 shot.
![Wink](https://ls1tech.com/forums/images/icons/icon12.gif)
i am pretty sure it will take n20-
