Strano Performance Hollow Swaybar set: $399 shipped
We are now offering our set of Hollow Swaybars for the price of $399.00 shipped by FedEx Ground service to any location in the Continential US.
If you need the bars shipped elsewhere, or by alternate method, please feel free to contact us and we'll get the details and work up a price.
You can order the bars here: http://www.stranoparts.com/partdetai...D=18&ModelID=7 It will show the car as 1998-2002 Camaro. ALL 1993-2002 Camaro's and Firebirds use the same bars, I am simply linking to make it easier for you find the item. If you'd prefer you can go to www.stranoparts.com and use the make and model list to pick your particular model of car.
The details:
-Set of front and rear sway bars
-35mm front, 22mm rear
-Lighweight hollow tubing saves approximately 5 pounds per set compared to OE bars
-Significant weight savings vs. solid aftermarket bar sets. 20 pounds lighter than 35/21-22 solid bar sets. Approximately 15 pounds less than solid 32/21 or 32/22 combinations.
-Complete with new endlinks, bushings and mounting bushings and brackets
-Black powdercoat
-Competition designed and proven. Used on multiple SCCA National Championship winning cars.
And the pic:
The details:
-Black powdercoat
And the pic:
![](http://www.stranoparts.com/data/images/p2231143929.jpg)
__________________
Right, and that's then got freight added on, and that's normally about $22-25 for a pair and can be more.
Single bars do NOT include shipping.
__________________
Sorry but there's not any special on individual bars.
__________________
Would the hollow front sway bar be a good alternative to removing the front bar for greater lift and traction for drag racing? Sam please pm me on this .. I'm in Lancaster Pa. so I can pick it up..Thanks
The stock GM front bar is already hollow, and significantly softer than mine is. My bar is to add roll stiffness, not take it away.
__________________
Yes, it left today.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
