Nitrous Outlet Summer Time Special!
Nitrous Outlet Summer Time Special!!
Race season is here and its time for car shows, local meets, and fun days at the race track. Be on top of your game with Nitrous Outlet!
We have put together a few special packages to help you kick off the summer with a bang!
Group 1.
LS1 or LS2 Plate special.
Your choice of a 85mm, 78mm, 90mm, or 92mm Nitrous Outlet Plate System with black 10lb bottle, Automatic bottle heater, Purge, Fuel pressure safety switch, Nitrous pressure gauge, Nitrous filter, NHRA Blow off fitting, Blow down tube and Digital dual stage window switch with built in TPS activation and gear lock out feature.
![](http://img359.imageshack.us/img359/2387/group1ls1fx0.jpg)
COST= 1106.00
Group 2.LT1 Plate special
Your choice of 52mm or 58mm Nitrous Outlet Plate System with black 10lb bottle, Automatic bottle heater, Purge, Fuel pressure safety switch, Nitrous pressure gauge, Nitrous filter, NHRA Blow off fitting, Blow down tube and Digital dual stage window switch with built in TPS activation and gear lock out feature.
![](http://img359.imageshack.us/img359/8286/group2lt1rx0.jpg)
COST= 1150.00
Group 3.
Single Nozzle special
Nitrous Outlet Single Nozzle System with black 10lb bottle, Automatic bottle heater, Purge, Fuel pressure safety switch, Nitrous pressure gauge, Nitrous filter, NHRA Blow off fitting, Blow down tube and Digital dual stage window switch with built in TPS activation and gear lock out feature.
![](http://img359.imageshack.us/img359/4060/group3snnn6.jpg)
COST= 971.05
Group 4.
This is for the guys looking for a budget set up minus a few bells and whistles with out sacrificing quality.
Brand X Single Nozzle Special
Brand X Single Nozzle System with black 10lb bottle, Automatic bottle heater, Purge, Fuel pressure safety switch, Nitrous pressure gauge, NHRA Blow off fitting, Blow down tube and Digital single stage window switch with built in TPS activation and gear lock out feature.
![](http://img229.imageshack.us/img229/3788/group4xkc9.jpg)
COST= 695.00
Group 5.
Nitrous Outlet Dry Halo system.
Your choice of the F-body or GTO dry Halo system with black 10lb bottle 860Billit bottle bracket / Automatic bottle heater combo, Purge, Fuel pressure safety switch, Nitrous pressure gauge, Nitrous filter, NHRA Blow off fitting, Blow down tube and Digital dual stage window switch with built in TPS activation and gear lock out feature.
![](http://img359.imageshack.us/img359/771/group8fhalomt1.jpg)
COST=845.00
This Special is good until August 1st. You can call in your order at 1-866-648-7637
Thank you for all your support!
Nitro Dave
Group 1.
COST= 1106.00
COST= 1150.00
Group 3.
COST= 971.05
Group 4.
COST= 695.00
Group 5.
COST=845.00
Nitro Dave
Dave I bought a GTO that the guy bought everything you offer lol. Monair is the guys name.
Anywayz he has the folding GTO switch Panel.![](http://www.nitrousoutlet.com/images.asp?type=product&id=2135)
and the front fuel system
![](http://www.ls1gto.com/forums/attachment.php?attachmentid=87734&stc=1&d=1215001808)
My question is he has everything hot on his arm switch on the panel. The NOSbus, the fuel system. Some times the fuel system turns off sometimes it stays on. He was saying that sometimes the wires get bent up or something that causes this. Also does it matter if the front fuel pump stays on all the time as long as there is fuel in there?
My only concern is when I use the nitrous I dont want to lose the fuel pressure due to wiring. Also on the AN blue 90 on the tank is that just to let the tank breath?
