keep the criticism to a minimum!
Old 01-29-2009, 06:20 PM
yeller_xtc's Avatar
Question keep the criticism to a minimum!
has anyone ever atempted to install an 18" subwoofer in a 4th gen. trans am?
Old 01-29-2009, 07:15 PM
F3RR3T's Avatar
I have did it in my buddies 96. Fi audio BTL on 4000rms. personally i am doing 2 Sundown Audio Nightshade 15's in a 6 cube ported box tuned to 34hz. on 10,400 RMS (5200 RMS per sub.
amps are Sundown Audio SAZ-3000d's on 16v
Old 01-29-2009, 07:41 PM
yeller_xtc's Avatar
any pics?
Old 01-29-2009, 08:03 PM
pentavolvo's Avatar
where do u plan on putting it, cause its gonna take a ton of room
Old 01-29-2009, 08:17 PM
F3RR3T's Avatar
no but i do have a picture of the box going in my camaro. (no dimensions do not want people copying the box (there are lot of details missing also)
Old 01-29-2009, 08:18 PM
F3RR3T's Avatar
TEST box has already been built and installed fit great
Old 01-29-2009, 08:56 PM
yeller_xtc's Avatar
sweet as model! i was thinking of a box like that but angled in the back ( like the prefab boxes are) to make room for the 18" sub.
Old 01-29-2009, 08:59 PM
F3RR3T's Avatar
do 2 15's if you can. more cone area therfore louder (in most cases)
Old 01-29-2009, 09:06 PM
yeller_xtc's Avatar
already have the 18" think you could design me a box that will fit? i can build it. id like to see your ideas.
Old 01-29-2009, 09:18 PM
yeller_xtc's Avatar
something like this is what i had in mind...keep the criticism to a minimum!-camaro1-1.jpg
Old 01-29-2009, 10:31 PM
ChevyS10sbc's Avatar
Just a question but, Why an 18" ?
Old 01-30-2009, 05:23 AM
yeller_xtc's Avatar
i like the super low note an 18" can produce. and the "wow' factor you get when someone see's what just made thier drink come out there nose...lol
Old 01-30-2009, 05:30 AM
BKDZ28's Avatar
alrighty then!
best of luck
Old 01-30-2009, 07:01 AM
yeller_xtc's Avatar
Originally Posted by BKDZ28
alrighty then!
best of luck
Old 01-30-2009, 11:03 AM
F3RR3T's Avatar
So what you think of this.
100 RMS on 2 sundown audio SD-1 12's amp is one channel on a Sundown 100.2
Did 141 DB sealed on the dash (mic was a audiocontrol about 138 DB on the termlab.
Old 01-30-2009, 01:47 PM
BIG_MIKE2005's Avatar
Guess your goin for SPL only & no SQ huh?
I have (1) 10 in a custom stealth with a Zapco 350i running it w/each channel to a voicecoil & it's loud as hell. Granted it doesn't shake my car like a SPL machine but it has a very nice tone & is plenty if your gonna be stayin in the car while it's on.
I used to do SPL & had my first car set-up with a single 15" Digital Design DVC sub on a 2200w amp then switch to a Kicker ZR1000(old school, LOL). It did 147 off the windshield & would play 19hrtz like no bodies business. Scott Shope built my set-up. He used to own the famous at the time knuckle dragger that was filled with 15" Vega Strokers.
Old 01-30-2009, 02:06 PM
F3RR3T's Avatar
that setup in my truck was a SQ setup. The system going in my camaro will be a bass race machine. but SQ for daily listening (15's can be turned off and the 8's in the sails can be turned on)
Old 01-30-2009, 02:34 PM
ahh, hidden 8's. I just used a great mid/high set with it's own amp to replace my stock speakers & then thru the single 10 in the back. I didn't think it would be enough but it has proven me wrong, LOL. I daily drive it so I didn't want to get too extreme. Plus I like to go to the track without having to remove a 200lb box first too. It's nice to bump all the way to the burnout box, LOL.
Old 01-30-2009, 02:43 PM
99Bluz28's Avatar
Lightbulb
something like this is what i had in mind...Attachment 163521
You'll probably get no more than a little over 3-3.5 cu.ft. , which isn't much space for a 18" sub. Have you thought about a rear seat enclosure?
That would give you a lot more room for a good sizes enclosure!
Old 01-30-2009, 02:49 PM
99Bluz28's Avatar
Any test fit pictures?
