replacing drl's on Trans Am Firehawk
If just replacing the bulbs then I can get them out through the hole in the bumper as well. If you want to replace the entire housing, then underneath is the best way to go. I replaced my housings with new ones when I installed the BLS HID kit. You wouldn't believe how bad the stock ones looked...guess it's to be expected for over 10 years.
Where in Texas are you?
Look for a pic of the DRL socket on here. There is a locking latch around the base of the socket. You have to hold down on that locking latch and then turn to get the bulb out.
I really dont know why you are having such difficulty removing the bulbs lol.
I live in Crowley Tx but I'm in graham at the moment. The problem is I can't really see what I'm doing under there. I'm gonna jack it up a lil so I can get a better view.
See that little clip on towards the bottom left? You have to squeeze that in and then twist to get the socket out of the DRL housing. I'm starting to think that maybe your socket melted and is now stuck to your housing, that's why you're not able to get it off.
Definitely, jack it up so you can see what you're doing.
