DIY pass window fix
DIY pass window fix
The pics from the original how-to thread are too old and are not being hosted anymore. Does anyone know of another write up for this? or have the pics somewhere?
Save the manuals!
That thread and the kit is for the dinosaurs. Dorman has come out with a new motor design that resolves the issues with the original circa-1969 motor that was put on the cars from the factory.
Going with the bypass is a very expensive and time consuming way to address a $35 problem.
Save the manuals!
The bypass will apply a slightly higher voltage to the motor, which makes a bad motor look better. You can also just fix the problem - which is really the crappy motor.
If you lookup the stock motor in a parts cross-reference, you'll find that it was installed on cars in the '60s. IMO - it really had no business in being on these 1990's cars in the first place.
This is internet mythology. The story/myth goes that there is a voltage drop in the wiring to the motor. The flaw in that is that the motors from the factory worked fine and the problem pops up on both sides of the car. (The voltage measured at the two motors is also over 12V, so there's no technical issue there.)
Save the manuals!
This is one of those things that you'll want to get from a local parts store, so you can see it in real life before you buy.
Originally AutoZone carried the new motor design, then Dorman picked it up as one of their branded products. Maybe Dorman has dropped it? I'd start with a trip to a local AZ and see what they have on the shelf.
I did not pick one up from the store, I pulled it out (AC Delco) of our totaled Bird that was in use about six months. Works amazing compared to the stock one, while I had the panel pulled I fixed the crack in the panel.......was a good day!
I thought the stock one would be AC Delco, but it was not.
I work at a dealership and I just had them send one over. Search this number on their site (88960088) seems to be sold through ACI Auto. I wont have it in my hands till tomorrow so I dont know for sure until then
