Dig to 140mph: LS2 A4 GTO vesus SRT8 Charger
#81
I ran used to run a Zex which is rated at flywheel I believe, its stupid rich with the jets they recommend. I changed out the fuel jets to lean it out. I know these cars like the back of my hand even though I didnt get my car dyno'd when it was a bolt on and 125 shot I know what these cars typically do with those mods. 535 is about the norm.
No weight reduction when I ran that 11.45 with bolt on and 125shot or when I ran that 11.85 cam only NA.
Did a good bit now along with some front runners and a couple things to get my short times down, and boy did it make a BIG difference. I would post my times but im kinda sorta into the street racing scene here locally and they might have some of my competition monitoring my posts! lol
Yeah the HEMI 6.1 is a very impressive motor but the lil 'ol LS1 still holds it's own too.
#82
So with a 350 shot your lookin at something like 730-760rwhp, hell id say that stock 6.1 hemi would get you in the 8's for roughly 8 passes!! Ever thought about puttin a HEMI in that F body?? lol jk
#83
Respectable times considering the enormous curb weight. Now with the weight reduction things should get exciting. About 11 years ago I use to run a '94 Imp so I know how good it feels to make a heavy car go fast.
#85
Here a couple videos of the stronger running H/C SRT'S. Note that we do not have aftermarket intakes available yet such as the FAST intakes. The best we can do is port our shitty stock intakes, and for some reason our community doesnt believe in big cams. A BIG cam for a H/C car is in the 225-235 range.
This guy says he ran this 4250 race weight NA.
http://www.youtube.com/watch?v=YBXq676A5vc
Another, hes gone 11.15 also.
http://www.youtube.com/watch?v=O20dsuNXc5g
#86
Yep thats about right. On a generous dyno u can see as high as 410-420 on a pump gas tune. Trust me these are not realistic numbers, there very much inflated. But hey it is what it is. On a heartbreaker dyno like the one i use a Cai,Catback,Tune 6.1 can make as low as 312rwhp but we have seen slightly higher but nothing nowhere near 350rwhp. I say screw dyno numbers just show me a gain and then im going where the numbers really matter!! The dragstrip!
#87
#88
Those cars move out well! And at 4,250lbs that's awesome. I was anxious to see what one of these cars will do with a big cam like in the 24x range. I'm guessing they don't benefit too well from large cams since most I see run smaller bumpsticks around the area of the one you've got. What about high performance rear-ends, ring & pinion options for these cars? I'd imagine a stronger rear would be needed soon after this stage and some shorter gearing would really help move the weight of this car.
As for rears n gears believe it or not we have a 4700lb magnum running 9.8's boost only with a ysi but hes about to slap a 200shot on top of that. Hes still running the stock open diff rear with stock gears!! You may have seen him it was on Speeds Pass Time.Mercedes makes some good ****.
Richmond does have gears options for us though and we have several Lsd options as well.
The new oem lsd getrag diffs r proving to be pretty stout as well as the stock axles. Guys are cutting 1.45's with them with no problems. They to come with three different gear options 3.06 3.73 3.92
#89
And if looking at stock numbers, SRT Engineers stated a 2% hp variance in production is acceptable along with air and coolant temp differences.
#90
Why would you say that? 400+rwhp is the standard around the country for a dyno tuned SRT-8. It's a very efficient transmission with a lock-up torque converter so at 16-16.5% loss, it's spot on vs. the rated crank hp.
I see alot of built blown cars claiming outrageous numbers and then they go to the track and run times and traps alot slower than our 600rwhp built blown cars.
Perfect example, I raced a built blown mustang from a roll and Murdered him without the spray. He asked how much I dyno at and when I told him 412 he like to ****. He said he was making 470+ rwhp and that it was built and dyno'd at StangHI performance. I then told him there was no way he's making that kind of power atleast not on our dyno. Just didnt add up, way heavier car spanks a lighter car thats supposed to be making a good bit more HP. He brought the car to our shop and it put down 320rwhp.
I do see what your saying though, maybe I shouldnt have said those were "unrealistic inflated" numbers. With the drivetrain loss % it is about right.
Our numbers just are "underinflated and unrealistic" in a good way that is. lol
#91
FINAL VERDICT: IF YOU DRIVE AN LS POWERED ANYTHING - (FBOD, GTO, VETTE) etc. OR AN SRT8 (CHARGER, CHALLENGER, 300C) YOU ARE OFFICIALLY A FUC*IN PIMP - THANK YOU AND GOODNIGHT!!!
PUSHROD MULLET SQUAD 4 LIFE!!!
#92
Yea i dont get why people dont put big cams in these cars. The shop i somewhat work for uses pretty big cams and hell u might know our cam grinder Ed Curtis od flowtech inductions. My baby cam was just a experiment cause we had it layin around the shop and what the hell why not. To our surprise its got my car running times that a weak stroker runs. The cams we use are in the upper 240's but with pretty wide lsa'a like 114-115. But Ed's making us a cam for a Hilborn Injected 419 Charger thats going to be the most radical cam these cars have see yet 240-250 with a 106 lsa.
#93
I believe the magnums stock curb weight is around the 4300-4400 area. Now add a full cage that i think is certified to rum 8's, a comple YSI set up and a 200lb driver and i think its pretty close to 4700 give or take a few.
Yea 106 is pretty crazy for a street car but this is going to be hilborn injected. The current cam in the charger is a 23x/24x@115 and it chops pretty good but when we put the hilborn injection on it it sound more tame than a stock car! No chop at all, smooth idle! It gained 60rwhp with heads and cam that arent even designed for it. So i think the 106 is gonna spit and pop pretty good but not like u would think it would. But who knows it might, this is a first on our engines.
Heres some pics of our other firsts...
#96
www.youtube.com/southernhotrod
www.youtube.com/robertsrt
Enjoy.
#97
Challenger is a Wide Body with 14" wide Pilot Sports on the back, not drag radial sticky but pretty damn sticky.
http://www.youtube.com/watch?v=k7Yw2Q1u1ng
The 300 is the one with the old school roots (671).
http://www.youtube.com/watch?v=c7hVicNPZmY
#99
On our dyno it made 620rwhp, on a Dynojet I would GUESS it would make 700+ easy.
#100
It has an Arrington ground cam in it that was intended to be NA, I dont know the exact specs on it but I know the lsa is pretty narrow which im sure you know isnt good for boost. We think if we were to get a proper cam in it it may pick up another 50rwhp easy.
