Street Racing & Kill Stories Basic Technical Questions & Advice
Cam/nitrous LT1 Z28 & C6 Z06 vs. bored/stroked 408 LSX Z28
Old 06-09-2010, 12:14 PM
IamSteve's Avatar
Default Cam/nitrous LT1 Z28 & C6 Z06 vs. bored/stroked 408 LSX Z28
Last weekend there were a few races, south of the border, of course. I've got a couple vids, but one of them has some language that won't allow it to be posted to a video host...I'm waiting for the audio to be edited. At any rate, here's one of the videos. It's the cam/nitrous LT1 vs. the bored/stroked 408 LSX; the LT1 takes the win, even riding +1 in the car! The vid of the C6 Z06 vs. the 408 will be posted as well.
I've always liked LT1's for their mad torquelz, but they usually get frowned on these days compared to new tech. I just wanted to throw it out there that the LT1 can hold it's own against built motors. The next vid should be the LT1 vs. the Z06; awwww, cuz. I've seen the LT1 and Z06 race several times and the LT1 does well. Good job with your car dude!
Old 06-09-2010, 01:01 PM
LT1forever's Avatar
I really didnt expect the LT1 to pull the 408 on the top end. Great kill non the less, any specs on the LT1? How big of a shot?
Old 06-09-2010, 01:19 PM
IamSteve's Avatar
I'll get the specs and how much nitrous he was running. As far as I've seen, the engine is all factory except the cam he slipped in and the ZEX system. I'll let you know today.
Old 06-09-2010, 02:09 PM
chavez885's Avatar
Hopefully the next video is better.....thanks for sharing though
Old 06-09-2010, 02:12 PM
IamSteve's Avatar
I'm know . It's the best that could be had with the iphone at the time. A REAL camera would help a lot.
Old 06-09-2010, 02:14 PM
IamSteve's Avatar
Didn't even think about it, but the specs on the 408 would help too. I'll post those too so it gives good grounds for comparison.
Old 06-09-2010, 03:13 PM
IamSteve's Avatar
Specs on the 408 car, copied from cardomain. Specs on LT1 car are coming:
6.7l 408ci LQ4/L92 IRONBLOCK STROKER
GM LQ4 IRONBLOCK
EAGLE FORGED 4340 4.000 CRANK
EAGLE FORGED 4340 6.125 H-BEAM RODS
MAHLE FORGED ALUMINUM 4.030 12cc DISHED PISTONS
MOLY PISTON RINGS
GMPP L92 HEADS MILLED TO ~65cc CHAMBERS
COMP CAMS CUSTOM GRIND: 243/247, .621(XFI)/.612(X-ER), 114+3 LSA
LS7 HIGH RPM LIFTERS
CLEVITE 77 P-SERIES BEARINGS
GMPP L76 INTAKE MANIFOLD
LS2 FUEL RAILS, 34lb/hr INJECTORS
HOLLEY 90mm THROTTLE BODY
85mm MAF SENSOR
MELLING HIGH-VOLUME OIL PUMP
LS6 VALLEY COVER
PRC .660 LIFT VALVE SPRINGS
TITANIUM RETAINERS, CHROMEOLY KEEPERS
TSP 7.400 HARDENED PUSHRODS
COMETIC MLS HEAD GASKETS, .040", 4.085" BORE
LS2 TIMING SET
GRANETELLI LID
PACESETTER FULL RACING LONG TUBE HEADERS
SUMMIT 3" X-PIPE CUSTOM TRUE DUAL EXHAUST
FLO PRO TWISTIE MUFFLERS
LS1 K-MEMBER SWAP WITH POLYURETHANE MOTOR MOUNTS
FULLY TUNED AT 10.9:1 COMPRESSION
SHIFTING AT 6500RPM
DRIVETRAIN
SELF-BUILT T56 6SPD TRANSMISSION WITH TICK PERFORMANCE STAGE 2 UPGRADE KIT
TEXTRALIA OZ700 CLUTCH, PRESSURE PLATE & BILLET STEEL FLYWHEEL
B&M RIPPER SHORT SHIFT SHIFTER WITH WHITE 6SPD PATTERN SHIFT ****
GM SLAVE CYLINDER WITH LPP REMOTE BLEEDER
LS1 DRILL MOD
SKIP SHIFT DELETE
LS1 ALUMINUM DRIVESHAFT WITH HEAVY-DUTY U-JOINTS
ENERGY SUSPENSION POLYURETHANE TRANSMISSION MOUNT
MOSER 9 INCH BUILT HOUSING
MOSER 31 SPLINE ALLOY AXLES
STRANGE NODULAR IRON S-CASE
DETROIT TRUE-TRAC DIFFERENTIAL
MOSER 3.50 GEARS
SUSPENSION
EIBACH PRO SPRING KIT
SLP BILSTEIN FRONT & REAR SHOCKS
SLP STRUT TOWER BAR
LS1 FRONT BRAKES
UMI PERFORMANCE TUBULAR REAR LCA'S WITH POLYURETHANE BUSHINGS
UMI PERFORMANCE TUBULAR FULLY ADJUSTABLE PANHARD BAR
UMI PERFORMANCE TUBULAR ADJUSTABLE TORQUE ARM
UMI PERFORMANCE TRANSMISSION CROSSMEMBER WITH TORQUE ARM RELOCATION MOUNT
CHASSIS
REAR SEAT, SEATBELT DELETE
A/C, ABS DELETE
CUSTOM WIRING HARNESS FOR ENGINE
WALBRO 255 FUEL PUMP
REAR-MOUNT BATTERY
SUMMIT ADJUSTBLE 1.6 INCH SHIFT LIGHT MOUNTED ON DASH
RS SPOILER ADDED TO BACK
BERGER PANEL MOD
LT1 car specs:
1996 Z28, 6 speed
Cam only...232/239 .476/.490 (stock lift with 1.6 RR) 112
Hooker LTs
Magnaflow cat back
K&N CAI
ZEX wet kit (shot still uknown....I'll find out)
Ported MAF
Stock heads/TB
Stock intake
stock 3.42s
Old 06-09-2010, 03:50 PM
Trunion King
bene's Avatar
Just let out of the bag, it's the_merv's car. IMO, 408 held it's own versus cammed Lt1, bolt ons with Nitrous. The question is how big of a shot was it?
Old 06-09-2010, 03:54 PM
IamSteve's Avatar
Not many bolt ons really. I'm getting with him on the shot. Taking me a minute to get the info cause he's a work....I'm just bored so I don't mind posting the info....stupid foot's hurt so all I can do it sit at a desk for a month. How you doing over there? Obviously, this is Steve from the Fire Dept at LRAFB and off ARRides.
Old 06-09-2010, 04:13 PM
I8ASaleen's Avatar
That's a very tame cam for that LT car, but sounds about right with stock heads.
IamSteve's Avatar
Forgot to mention, the LT1 was riding +1 in the car...fixed 1st post.
Old 06-09-2010, 04:18 PM
Trunion King
bene's Avatar
To be honest, the novelty of being in England wore off. I miss the land of the Free. Bigger with everything, convenience... I'm sure this will change again when I get my *** to do a little trip to Germany w/ the camaro.
Old 06-09-2010, 04:21 PM
IamSteve's Avatar
Oooooooo, a little Autobahn top speed run, eh? Make sure the tires are in good shape and speed rated . Should run fast. Pick some "fights" too while you're on it
Old 06-09-2010, 05:53 PM
registered user
ScreaminRedZ's Avatar
Good race! That LT1 looks like it's a strong runner.
Old 06-10-2010, 07:05 AM
IamSteve's Avatar
I'll admit, I was very surprised at how fast it is, especially with the minimal mods that are done to it.
Old 06-10-2010, 07:11 AM
gregrob's Avatar
Nice vid. I have vids of my baby cam only + spray beating on some faster cars too. A 408 lsx being one of them.
Old 06-10-2010, 07:16 AM
IamSteve's Avatar
Nice dude. That means this race wasn't a fluke then, since you've done the same thing. I'm telling you, that LT1 in the vid is a good run on the Z06. Z06 has intake, tune, exhaust.
Old 06-10-2010, 07:59 AM
gregrob's Avatar
Not trying to hijack or take anything away from the original story but here's a couple:
C6 Z06
http://www.youtube.com/watch?v=Xp6NhmzGp5A
408 Stroker Camaro. Clutch slips badly when I fall back. It finally grabs in 4th and I pull around him easily. I would have been way out on him with a non-slipping clutch, you can hear me peddling it over and over trying to get it to hook. Re-race video to come. Then he will spray and kill me, he plans on a big shot. 250ish
http://www.youtube.com/watch?v=JDMTyxnRyLY
Old 06-10-2010, 10:00 AM
IamSteve's Avatar
Nah man, no hijack worries.
Wow dude. You weren't joking; pulled HARD in the second vid once you got it going. Good job on the car!
Old 06-10-2010, 10:08 AM
krissoto's Avatar
I don't care how big of a shot he was running. Unless that bolt on LT1 car had that motor in a go cart, that 408 should have ate him alive. I fig there was something going on with it. It just don't add up
