08cobalt ss vs 08 supercharged SI VS 05SRT4
The thing is, like what was already said, it's an algorithm that's built into the PCM that cuts ignition timing, allowing for a small window of opportunity to NLS to keep boost up as well as allow a nice "smooth" transition for the synchros in your transmission to mesh easily.
OP,
Good kills on both cars.
Now do yourself a favor and have someone tune over that S1 for you
Some people are seeing some great gains
no dyno numbers, but i am guestimating around 330/380 or so based on other cars, my tune, and what I have ran with on the street. but dyno numbers are just that numbers, it is what it is.
best part of the trifecta tune is you can toggle between stock and tuned with the push of the TC button. love it.
damn plastic shitty shift linkage, i was running a vette from a 40mph 2nd hit and banged 3rd and it popped right off and i had no gears
i had it towed to the dealer and it was like a week and a half till they could look a it. f that. I went to a local j yard and got the part and fixed it my self.
#32
Why would to want to nls 1-2? That thing probally already spins second. I know my neon did. 1-2 quick shift, 3-5 NLS. have any of you guys with turbalts ever ran on a track? I haven't seen a turbo one run at my local track. 300+ horse with some tire in that light car should net you a pretty decent time if you can launch it.
#33
guy over on css.net ran a 12.0 at 116 at 25psi, catless dp, charge pipes and intake. stock IC. no weight reduction, no meth, pump gas
ran lsj brakes up front and some suspension mods with a full slick
not bad!
not bad!
#34
2nd roasts even when not used
i did on stock contis at the end of their life
best et 14.01
traps all 105
launchin was a BI**H.......wheel hop or spin
#35
my 2nd is useless from a roll at 40 mph. my 1st gear is actaully tq limited, gets only 7 psi.
i hit the gas in 2nd at 4k and its like I am on ice.
i run bfg drags up front when I am out on the street screwing around
#36
I hear the combo gm tune + hp tune + trifecta tune traps like 116.
thats ****** crazy
#38
Is that even possible? lol
#40
i have ottp rotated mounts, rotate the engine a bit forward to align the axles. no more hop
yes you can run a few tunes loaded into the pcm. vince from trifecta cracked that a while back. you can have the stock tune under normal conditions, dealer visits, valet, etc. hit the TC/cruise/even fog light button and you have the tune of your choice. 24 psi or gmpp stage 1 or a meth tune whatever you want. best part is the trifecta is not detectable by a gm tech when you visit the dealer.
i believe he said there is room for like 5 tunes on the pcm. isn't technology wonderful?
currently you can have the gmpp stage 1 tune or you can have an hptuner or trifecta version of that tune using the 3 bar map that comes with the gm tune(allows to read over 22.5 pounds of boost that the stock map can't handle).
Also, you can have just the gmpp tune, a trifecta tune not based off the gmpp tune with the stock sensor(which is what I have, vince has found a way to get passed the 22.5 psi limit without the gm sensor), or you can have a straight hptuner tune. However. a straight hptuner tune can't read over 22.5 pounds currently, so there is the "pill mod" which kind of tricks the computer, but i won't get into that
all kinds of options.
my 1st does suck anyway you slice it, so i start my races from 2nd at 40mph, right at 4k
